Help!... 04 Tacoma SR5 4x4 tranny problem?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Desiel, Jan 6, 2011.
  1. Jan 6, 2011 at 10:27 AM
    Desiel
    Desiel [OP] Well-Known Member
    Kyle
    Morristown, TN
    01 Tacoma XtraCab SR5 4x4
    So far: Tint American Racing Wheels with 265/75-15
    I'm not sure if I am having a tranny problem or what it is really but here's what I have:
    2004 Tacoma SR5 4x4 Automatic
    180,000 miles
    and here's what it is doing to the best of my observation:
    in Overdrive, going up a slight grade, usually seems that it does it at low rpms(1500 to 2000) feels like it is trying to jump out of gear for a second then right back in, but if you hold it around the same rpm it will keep doing it. It's almost a jerk feeling. So I did a lil experimenting and it seems that it only does it in OD as I turned the OD off and it didn't do it but I wasn't in that low rpm range then.
  2. Jan 6, 2011 at 10:31 AM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    Have you checked the trans fluid to make sure it's at the right level? If that's fine I would say the only other thing would be if one of the bands in the trans is going. You've got quite a few miles on it.
  3. Jan 6, 2011 at 10:37 AM
    Desiel
    Kyle
    Morristown, TN
    Ya I checked the fluid... I was afraid it could be the tranny but someone suggested to me that it could be missing to replace the plugs and wires.
  4. Jan 6, 2011 at 10:38 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    You should be throwing a 300 series code it were missing that bad.
  5. Jan 6, 2011 at 10:41 AM
    Desiel
    Kyle
    Morristown, TN
    I'm fairly sure it's gonna be something with the tranny but geuss I'll take it to the shop and see what those guys think.
