Help! 3rd gen coolant
Discussion in '3rd Gen. Tacomas (2016-2023)' started by fng13, Aug 13, 2019.
  1. Aug 13, 2019 at 10:05 AM
    tcjacado
    tcjacado Well-Known Member
    Put the @ in front of the user name to speak directly to them or quote their post.
    @fng13
  2. Aug 13, 2019 at 10:06 AM
    fng13
    fng13 [OP] Active Member
    tcjacado likes this.
  3. Aug 13, 2019 at 10:11 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    No!!
    whatstcp and na8rboy like this.
  4. Aug 13, 2019 at 10:17 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    The Lexus GS 350 is same, 15 to present is the 2GR-FKS, 13 to 14 was 2GR-FSE. But was the same engine block.
  5. Aug 13, 2019 at 10:21 AM
    fng13
    Ok, can you tell me where they were located then?
    na8rboy[QUOTED] likes this.
  6. Aug 13, 2019 at 10:27 AM
    na8rboy
    WI
    I wish I could, not near either on of them. Out of town, it was over two years ago, when I drained/changed Lexus coolant.
  7. Aug 13, 2019 at 10:34 AM
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    Are they the same /type/ of coolant - as in organic, acidic, etc? If so i wouldn’t worry too much.
    Ive heard dexcool can become corrosive if mixed with an old school green coolant
    NTSALL4 likes this.
  8. Aug 13, 2019 at 10:35 AM
    fng13
    I'm not using DexCool.
    The only 2 fluids at play here are Toyota Long Life, and Toyota Super Long Life coolant. There is no off brand coolant here at all. It's 2 different toyota OEM coolants.
  9. Aug 13, 2019 at 10:43 AM
    na8rboy
    WI
    I just found on 2GR-FKS engine pdf. It say's if you mix the two (SLLC, and LLC) Just change it every 25,000 miles, or 24 months. It's listed on page 94 of pdf.
    davidstacoma, AKGSD and tonered like this.
  10. Aug 13, 2019 at 10:50 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That's a good read!
  11. Aug 13, 2019 at 10:53 AM
    BarcelonaTom67
    BarcelonaTom67 Lost in Translation....
    Tom
    Laurel County, Kentucky
    2017 Barcelona Red Off-Road DCSB M/T
    That drain seems waaaay too high up on the block to me. Gravity ain't going to allow very much to drain out from that location.
    Big tall dave likes this.
  12. Aug 13, 2019 at 11:02 AM
    fng13
    Great thank you guys, that at least eases my worry for now. I will still want to drain in fill with SLLC but that makes me breath a little easier.
    I agree with @BarcelonaTom67 that diagram shows it too high on the block. I looked all over the drivers side and cant see anything. There is a bolt that looks to be pipe/taper threaded, but there is no drain port cock like has been on other models (where you'd hook a hose to, to help drain) on it either. It also was in tight, torque spec on it the proper drain plug is only around 40 ftlbs or something, and i was leaning on this and it wouldn't crack. I was afraid to force it, not knowing if it's the right plug.
  13. Aug 13, 2019 at 11:05 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome!
    If it was me, I'd leave it for a while. Maybe hit it when you tag 100k?
    The full 3rd Gen Service Manual might have more information? It is floating around this forum somewhere.
  14. Aug 13, 2019 at 11:07 AM
    BarcelonaTom67
    Tom
    I just passed 40K on my 2017 Off Road, and still running the original factory coolant. I have been thinking of changing it at 50K.... but would like to have the question of 'Where are all the drains' before I start crawling around under the truck :)
    grubburg likes this.
  15. Aug 13, 2019 at 11:19 AM
    #35
    na8rboy
    WI
    If and when you do find it. It is a tapered plug, not port cock like older models, and torque is 13 N m ( 9 ft-lbf) per Manual.
  16. Aug 13, 2019 at 11:32 AM
    #36
    fng13
    Yep you're right it's 9lt lbs not 40 like i said earlier. I'm pretty sure i found then the right plug but it would not budge. It was in way tighter than 9ftlbs. I was afraid of really leaning into it on an aluminum block.
    I'll see if can get a picture of it later this week.
  17. Aug 13, 2019 at 11:34 AM
    #37
    fng13
    I'm going to keep searching to see if I can confirm I found the right plug, it'll naw at me until i get it changed out. Good to know i have a buffer of until 100k if i need it though.
    na8rboy and tonered[QUOTED] like this.
  18. Aug 13, 2019 at 11:37 AM
    #38
    na8rboy
    WI
    There is a thread sealer on it. That's why it will not come out easily. I know what you mean, by cranking on it to much. Always scary, with aluminum block.
  19. Aug 13, 2019 at 11:40 AM
    #39
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Tag for future use - quickly approaching 100k here - about another year.
    How does the Toyota dealership swap the fluid? Do they have a machine that pressurizes the system to force all the old stuff out before putting in the new coolant?
  20. Aug 13, 2019 at 12:01 PM
    #40
    na8rboy
    WI
    Yes, they have a Vac/Fill/fluid echange, or similar machine.
