HELP!! 92 celica starting problems HELP!! turn key and goes click most of the time
Discussion in 'Technical Chat' started by sernaj64, Jun 17, 2012.
  1. Jun 17, 2012 at 1:35 PM
    sernaj64
    sernaj64 [OP] Aight
    Juan
    honolulu
    2011 prerunner V6 SR5
    N fab Step bars BHLM by Asianants Pro Comp 2.25" level lift kit rear leaf TSB
    well i know this is a tacoma site but id thought it give you handy mech's here a shot also
    ok so here is the deal. and i thank you guys in advance for any and all help.
    so to start i have a 92 celica GT liftback.
    so when i go in to my car everything looks good (ill add a vid later.)
    all the lights come on and when i put the key in its sounds good the dinging sounds and when you turn one click the dashlight all turn on and you get the beeping sound and when you go to start it goes "click" and nothing happens no eng turn over nothing then i go back and try again same thing happens or it might turn on after that. after a couple of tries. it does it mostly after it sits there for a bit. but it can happen after being on for a while. again any and all help would be greatly appreciated.
    have you had this problem before?
    how did you fix it?
    how much to fix?
    is it an easy fix?
    http://www.toyotacelicas.com/forums...blems-help-turn-key-goes-click-most-time.html
  2. Jun 17, 2012 at 1:36 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    try a new battery
  3. Jun 17, 2012 at 1:38 PM
    sernaj64
    sernaj64 [OP] Aight
    Juan
    honolulu
    even if all the bells and whistles come on?
  4. Jun 17, 2012 at 1:39 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    what does the battery and battery terminals look like? aer they corroded? are the battery terminals nice and secure on the battery posts? wiggle them and see if any of them are loose. maybe it's as simple the battery not having enough juice to turn the starter motor and you need a jump start.
  5. Jun 17, 2012 at 1:41 PM
    MonkeyProof
    SoCal- SGV
    if your battery is indeed dead now you will need to figure out why. once you you get it running i would suggest to go to a reputable mechanic and have the charging system tested. maybe the alternator is going out and not properly charging the battery, or it's just time to replace the battery. a typical battery will last a few years before replacing
  6. Jun 17, 2012 at 2:13 PM
    sernaj64
    sernaj64 [OP] Aight
    Juan
    honolulu
  7. Jun 17, 2012 at 2:23 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    take the battery to autozone or the likes and have them test it.
  8. Jun 17, 2012 at 2:25 PM
    sernaj64
    sernaj64 [OP] Aight
    Juan
    honolulu
    any other options?? fixes??
  9. Jun 17, 2012 at 2:25 PM
    sernaj64
    sernaj64 [OP] Aight
    Juan
    honolulu
    yeah im going to in a few min
  10. Jun 17, 2012 at 2:26 PM
    2ski4life7
    2ski4life7 Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    Its most likely your starter. If everything powers on and it's not your battery then it's your starter. If that's not it could be your ignition switch. Had my corolla do the same thig except sometimes it would click and sometimes it would start. Replaced the starter and good as new.
  11. Jun 17, 2012 at 2:29 PM
    sernaj64
    sernaj64 [OP] Aight
    Juan
    honolulu
    yeah thats wh at happens it will click once twice three times shot even up to six then it starts
  12. Jun 17, 2012 at 2:31 PM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    FOX 2 1/2" CO's STOCK UCA's - They used to be Icons! Icons suck!!! TSB Rear w/Bilstein 5100's - Air Lift System - Leer 550 Bedcover - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    Clean the battery terminals and cables, even if they look okay. It doesn't take much. Next would be starter solenoid IMO.
  13. Jun 17, 2012 at 2:32 PM
    0psi
    0psi Well-Known Member
    Tommy
    Westminster/glen burnie Maryland
    Color match handles,sport hood,fx-r retrofit,fog light any time,eclipse avn726e
    Go to toyota and get a new set of starter contacts (there cheap) and that should fix it.common problem on that car.
  14. Jun 17, 2012 at 2:48 PM
    sernaj64
    sernaj64 [OP] Aight
    Juan
    honolulu
    lol i heard coke does an awesome job of that
  15. Jun 18, 2012 at 7:42 AM
    CrutchfieldDarren
    CrutchfieldDarren Well-Known Member Vendor
    Darren
    Right on! I replaced the contacts and the plunger which hits and spins on the contacts as well on my old 00 Taco. This is a common fix for a lot o the japanese starters ;). Cheaper than a new starter.
    May check with a local starter and alternator shop to see if they can either supply the parts or fix it for you.
    Best luck!!
  16. Jun 18, 2012 at 9:21 PM
    joes06tacoma
    Joe
    Central Coast, CA
    This is key. Starter contacts will cause this symptom. VERY common on Toyota products and can be cheap to fix if you buy the contacts only from the dealership or an auto electrical shop. There is usually a number on the starter that they will need to get the right part.
    It would be prudent to check the battery first. A quick way to do this is to turn on the headlights and hit the key. Have someone watch the headlights and see if they dim. If the battery is dead or weak, the lights should dim or go out. If everything stays bright, chances are good that the problem is in the cable connections or the starter contacts.
