Help a girl out? What's this noise?? 2001 Tacoma 3.4L V6
Discussion in '1st Gen. Tacomas (1995-2004)' started by _Lisa_'01Tacoma4x4, Jul 30, 2020.
  1. Jul 30, 2020 at 6:34 PM
    _Lisa_'01Tacoma4x4
    _Lisa_'01Tacoma4x4 [OP] Well-Known Member
    Lisa
    SoCal
    2001 Tacoma 3.4L V6 4x4 Dcab
    Lifted (not sure of height), Falken RockyMountain 285/75/16 tires, unsure of wheel details, auto leveling kit, moded to HID H4 headlights from previous owner. Recently Upgraded to LED headlights.
  2. Aug 1, 2020 at 11:58 AM
    _Lisa_'01Tacoma4x4
    Lisa
    SoCal
  3. Aug 1, 2020 at 11:59 AM
    Xperivent
    Xperivent Well-Known Member
    ‘24 Supersonic ORP & '04 Impulse Red DC OR
    A/C Idler pully makes a similar sound when the bearing goes bad
    Yota4Life89, Coprod and wilcam47 like this.
  4. Aug 1, 2020 at 11:59 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Sounds like air in the rack me if I had to guess. Have you turned the wheels full lock left/right a few times?
  5. Aug 1, 2020 at 12:04 PM
    SCORPION 1A
    SCORPION 1A Well-Known Member
    Buffalo, NY area
    2017 TRD Off Road - Inferno
    I’m about 80% sure it’s a pump going bad OR a Flux Capacitor.
  6. Aug 1, 2020 at 12:20 PM
    _Lisa_'01Tacoma4x4
    Lisa
    SoCal
    Yes, many times. Doesn't seem to get any better than that... ‍♀️
  7. Aug 1, 2020 at 12:21 PM
    _Lisa_'01Tacoma4x4
    Lisa
    SoCal
    PS pump (& resivour) was just replaced few weeks ago.
  8. Aug 1, 2020 at 12:23 PM
    0xDEADBEEF
    Did the noise start after you changed any part in particular?
    wilcam47 likes this.
  9. Aug 1, 2020 at 12:23 PM
    _Lisa_'01Tacoma4x4
    Lisa
    SoCal
    Even when I'm unable to run ac at the moment? (Still no No freon after repairs)
  10. Aug 1, 2020 at 12:55 PM
    0xDEADBEEF
    Yeah, that pulley is always spinning. Might be able to get a better idea of where it's coming from looking down on the engine with the hood open
    cruxofthebisquit likes this.
  11. Aug 1, 2020 at 2:02 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    You could always disconnect the suspected belts and see which components still are making noise.
  12. Aug 1, 2020 at 2:29 PM
    01tacoruben
    01tacoruben Active Member
    Ruben
    Ontario, California
    01 white tacoma extra cab 3.4 manual 4x4
    6inch Fabtech lift. 33 inch tires
    Does it make any noise on start up? How are your belts?
  13. Aug 1, 2020 at 2:36 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Yes. take off 1 belt then the other, spin all spinning parts. It's 1 of them. You'll find it.
  14. Aug 1, 2020 at 2:39 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The sound is too vague to say one way or another. You need to pop the hood and pinpoint the noise then take a video of it to better approximate and make educated guesses as to what it is.
    Take a long flathead screwdriver and use the handle as a listening tool while pressing the tip against the body of the items in question to see where it comes from.
  15. Aug 2, 2020 at 12:19 AM
    _Lisa_'01Tacoma4x4
    Lisa
    SoCal
    Ok. Lemme find the videos I took throughout all the repairs... (I documented everything)
    I'll also show ya, what exactly all the repairs were done... (I don't think I worded that right, but you get what I mean to say). ‍♀️
    Sorry I'm tired. ☝️
    12TRDTacoma likes this.
  16. Aug 2, 2020 at 12:28 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Any little bit helps!
  17. Aug 3, 2020 at 5:18 PM
    _Lisa_'01Tacoma4x4
    Lisa
    SoCal
    Ok so here's what was the initial problem was... noticed a substantial leak...(back in Feb)
  18. Aug 3, 2020 at 5:19 PM
    _Lisa_'01Tacoma4x4
    Lisa
    SoCal
    First startup after repairs and leak fixed...
    davidstacoma likes this.
  19. Aug 3, 2020 at 5:21 PM
    _Lisa_'01Tacoma4x4
    Lisa
    SoCal
    And then again, a day later...
    So replaced PS pump (w/ resivour)
  20. Aug 3, 2020 at 5:25 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I sort of hear it now. So let me ask you a question, after you replaced the pump and reservoir assemblies did you bleed the system or did you just put on the cap and call it good?
    Also, try turning your wheel hard to the left or right and hold it for a few moments, does the noise increase or does it sound the same?
