Help a noob!!
Discussion in 'Audio & Video' started by BlueNorthToyo, Mar 22, 2009.
  1. Mar 22, 2009 at 9:15 PM
    BlueNorthToyo
    BlueNorthToyo [OP] Well-Known Member
    07 DBL Cab, TRD, SR5 & Tow Package, 3" Lift
    3" Revtek lift, Access Laredo Tonneau Cover (awaiting delivery), Debagged Tailgate, Pop and Lock Tail Gate Lock (awaiting delivery), Grom I-pod hardwire, Chrome Side Step Bars, Hood Deflector, Window Vents, 15" Stubby Antenna, GE NIghthawk Headlights, Fog Light Mod, Hose Clamp Tailgat
    Hello to all you audio guru's. This is my first dabble into the world of car audio. I upgraded my HU from the stock non JBL system to this sony unit (http://www.sonystyle.ca/commerce/se...productId=1005532&navigationPath=n32150n32153)
    This weekend I installed new speakers in the front and rear doors. They are Alpine type S speakers like the ones here. I put 6.5 in the rear and 6x9 up front. (http://www.alpine-usa.com/US-en/products/product.php?model=SPS-69C2)
    While the highs and mids are much better than stock, the low is lacking. I was wondering if I should upgrade to an amp and sub or if I should return these Alpine coaxial speakers and replace them with these Pioneers (http://www.pioneerelectronics.com/PUSA/Products/CarAudioVideo/Speakers/D-Series/Pioneer/TS-D1720C)
    As I said I am very very new at this game and would appreciate any advice you can give.
    Thanks
  2. Mar 22, 2009 at 9:32 PM
    bass mechanic
    bass mechanic Well-Known Member
    colorado springs, colorado
    2009 tacoma Access cab TRD offroad in black
    none
    make sure the speakers are wired correctly, make absolutly positive you wired each speaker with the correct polarity + to + and - to - on each speaker and the head unit, if you cross 1 speaker, both will have little to no bass, an easy way to test is to pick a radio station thats all static. turn the volume up a little and fade from right to left and back to center. you should notive a much more full and better bass responce in the center verses the sides. if 1 of the speakers is wired wrong there will be more bass on 1 side or the other verses in the center.
  3. Mar 22, 2009 at 10:26 PM
    BlueNorthToyo
    Do you know off hand which is the + and which is the -.
  4. Mar 22, 2009 at 11:52 PM
    TightShirts
    TightShirts The StormTrooper
    TightShirts
    Phoenix... The Land of Lifted Trucks & Dirty Sluts
    08 Rugged Trail Ed
    Tint, Clear Bra, De-badged, In-Dash DVD, 09 Led Tail Lights, Chris4x4's old OME front shocks, 1.5" Deaver AAL with OME n182s, black billet in white sport grill, BHLM w/4500k HIDs + Fogs, bumper blackout
    a component set-up up front is going to sound MUCH better than just 6x9 replacement... changing them out is going to greatly improve improve the sound but a sub will give you more bass, so it depends on how much you want to spend and how much stuff you want to add to your truck.
