HELP: Am I sagging??
Discussion in 'Suspension' started by cdavi060, Mar 22, 2011.
  1. Mar 23, 2011 at 9:47 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Well I was 35 1/2" from the ground stock but mine was sagging a little.
  2. Mar 23, 2011 at 11:46 AM
    cdavi060
    cdavi060 [OP] Well-Known Member
    Virginia Beach, VA
    2016 TRD Sport 4X4 DCSB
    Full OME Lift (887), 275/70/17 BFG KO2
    I am at 35inches all the way around. Guess I am sagging...
  3. Mar 23, 2011 at 1:24 PM
    cdavi060
    Virginia Beach, VA
    I just about ready to oder and want to make sure I got everything straight:
    If I order the 5 leaf pack from wheelers, and purchase the OME 881 springs and the OME NitroCharger Shocks all around. I should have a completely level truck with about 2.5in of lift from stock height??
  4. Mar 23, 2011 at 1:26 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    correct. Look at my build as well as MTgirl and socar's trucks for examples of basically that exact same setup (other than the D-cab). Tacomaman06 is also running that exact setup so you can look him up.
  5. Mar 23, 2011 at 1:40 PM
    cdavi060
    Virginia Beach, VA
    awesome. Ill take a look. How is the ride by the way? Stiff or close to stock?
    Should be able to fit 32s(265/75/16) under it after the lift correct?
  6. Mar 23, 2011 at 1:42 PM
    JLee
    Jerry
    Grass valley CA
    You should be able to fit that stock so you should be good.
  7. Mar 23, 2011 at 1:43 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Ride is stiffer, but not harsh at all. Rough roads actually feel smoother than before.
    And you can fit those tires stock. With some trimming you could even fit 285/75/16's if you want. I had 255/85/16's (33.3x10) on mine for almost a year with minimal rubbing.
  8. Mar 24, 2011 at 10:11 AM
    cdavi060
    Virginia Beach, VA
    This is the lift height I am trying to achieve:
  9. Mar 24, 2011 at 12:29 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    you should be sitting pretty much exactly like that green truck in the end. Not quite as high as the red one though.
