HELP! Any car seats that will actually work in a 05 06 access cab?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jinxed77, Mar 3, 2012.
  1. Mar 3, 2012 at 12:37 PM
    jinxed77
    jinxed77 [OP] Well-Known Member
    06 4.0L TRD SR5 4x4
    I have a 06 Tacoma Access Cab. I finally installed my old car seat in the back but i had to disassemble the car seat to do it. The issue is the top anchor strap has a release button thing.(Not sure what it's called) Well it is too big to fit through the upper anchor bracket on the truck.
    So I bought a new one recently a Safety 1st that has a smaller buckle.It's the smallest one i could find. It's still a no go. What the hell are us Access Cab owners suppose to do to get a car seat n the back facing forward?
    How are you other members with access cabs installing a forward facing car seat in the back? Is their another brand that will fit? Evenflo and Graco are both a no go. The Safety 1st is closer but still not small enough. Is their a larger updated upper loop available for the truck?
    Any help would be greatly appreciated.
  2. Mar 3, 2012 at 12:57 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I use a small carabiner for rock climbing to clip the strap thru on the Graco conversion seat we are using now.
    My sons Britax Marathon fit back there and the clip ran thru the anchor point- but once he started getting bigger his legs were stuffed in too much.
  3. Mar 3, 2012 at 1:07 PM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    rear facing? forget it.
    front facing? pics please.
  4. Mar 3, 2012 at 6:42 PM
    jinxed77
    06 4.0L TRD SR5 4x4
    Brunes does yours look like this one or smaller? My Evenflo same as the Graco that i looked at and or own are bigger.
    [​IMG][​IMG]
  5. Mar 3, 2012 at 6:45 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    The one I have now looks similar and I use the carabiner to route the strap.
  6. Mar 4, 2012 at 5:42 AM
    jinxed77
    06 4.0L TRD SR5 4x4
    Toyota should be forced to recall this and provide a updated loop that will actually work. This is a serious safety concern in my opinion. A child's car seat must have been a after thought that they didn't put much thought into at all.
  7. Mar 4, 2012 at 7:30 AM
    8BoltRacing
    8BoltRacing Custom Fabrication and Performance
    Jared
    Greensburg PA
    The Angry Warthog
    DO 3 hoop, Wheelers HD Leaf Set w/ES poly bushings, OME 884X Coils, 5100's, Selfmade Satoshi, Single beam headlights, Fogs anytime, high beams with low beams mod, ABS kill switch, AMSOIL fluids in everything, K&N Intake, TB Spacer, FAL Electric Fan and TRD Rad Cap, DT Long Tubes, URD Y-pipe w/xtra O2 bungs and 3" v-band , Custom 3-inch Exhaust w/v-band and 3030XL Aero turbine muffler and Aero 3040 tip, URD Fuel Pump Upgrade, B&M Short Shifter, EBC Dimpled and Slotted Rotors with EBC Yellowstuff pads, Pulseplugs, HIDs: Fogs 3000k, Highs 4300k, Lows 8000k, URD Throwout Bearing Repair kit, Fidanza Aluminium Flywheel+Competition Clutch Stage 4
    I have an 06 and I don't have any problem with either of ours. I'll check in a few hours when i get home what brand they are.. think graco and safety 1st
  8. Mar 4, 2012 at 7:37 AM
    elmo7
    elmo7 Easily Replaceable Member
    SC
    07 DC TRD OR 4x4
    I got a double cab just for the extra room req'd for my kid.
  9. Mar 4, 2012 at 10:15 AM
    teamfast
    Winnipeg, Manitoba
    '10 DCLB
    x2
  10. Mar 4, 2012 at 10:21 AM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    Wow, that's helpful.
  11. Mar 4, 2012 at 10:24 AM
    Fightnfire
    Marysville, WA
    We use a Britax Marathon for out little guy, 1.5 yrs now. He sits behind me, I end up one or two clicks father up than when I am solo and all the way back. Out of the 4 or 5 we have had this one by far gives us the most room.
    My 3.5 year old uses a Graco nautilus, shown in the first pic, it turns into pure booster when we need it. I picked this one up specifically because it's skinny front to back and fit well.
    Both of these pics show actual sitting position of my wife and I. I'm 6'1"ish, my wife is 5"8"
  12. Mar 4, 2012 at 10:26 AM
    05sctaco
    05sctaco Well-Known Member
    Ken
    Santa Cruz
    I've put a car seat in plenty of times in the back. The 05 has a removable plastic cover by the rear window. I take that off. Snake the seat belt through the car seat. (Usually in through the back or back and lap). Attach the top hook which looks like the one posted and tighten everything down. Has worked just fine with no problem and the kid is strapped in tight.
  13. Mar 4, 2012 at 10:31 AM
    Fightnfire
    Marysville, WA
    Forgot to mention, in the 09+ you really almost have to do the rear headrest removal to get any room. The headrests are huge and force the seat into a very weird angle. Taken out, tons of room.
  14. Mar 4, 2012 at 5:45 PM
    jinxed77
    06 4.0L TRD SR5 4x4
    05sctaco, Yeah the upper loop on the back wall by the window is my issue. It's just too little for the piece that says lift in my photo to go through it like the toyota owners manual says. I went all over town looking for the smallest one i could find.
    I'm going to get you guys some photos together tomorrow so you can see what i mean.
    Does the 09 model have the same anchor set up as the 05 models?
  15. Mar 4, 2012 at 7:36 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I don't know about the anchors, but the jump seats are completely different and look like they would work really well for car seats, unlike the 05-08 design.
  16. Mar 5, 2012 at 7:01 AM
    jinxed77
    06 4.0L TRD SR5 4x4
    This is the upper loop on my 06 that i'm having trouble with. I can't find any car seats with a strap that will actually fit through it. The only way i can get it to work is take the tether out of the car seat and feed it through in reverse order. Whoever came up with this set up i would like to know who they are so i can kick them in the balls.
  17. Aug 19, 2013 at 8:26 AM
    Connada123
    Connada123 Member
    I know this is an old thread, but I ran into this problem this weekend and wanted to post a reply for anyone else that comes across this. Hope I can save someone a headache.
    I have an 05', I managed to install a Graco Nautilus 3-in-1 front facing in the back of my truck, however the top LATCH strap would not initially fit through the top anchor as previously shown by the OP. I had to disconnect the strap from the car seat (very easy to do, once you see how the strap is connected to the car seat you can easily figure out how to disconnect and reconnect it), and lace the strap in reverse, from the second anchor, to the top anchor, and back to the car seat. Worked well, and as long as you reattach the top anchor strap back to the car seat correctly, I believe the integrity of system is uncompromised. Based on the two other car seats I have, I think this method would work for any Graco, not sure about any other brands.
    Because there isn't any padding on the folded down rear seats, I found that it was nearly impossible to get the bottom strap tight enough to prevent me from moving the car seat around. I took an old foam sleeping pad (used for camping), and cut it into three sections, put the three layers under the car seat to provide some padding, and was able to push the car seat into the padding and tighten up the bottom strap so that the car seat wouldn't move. Car seat feels pretty solid at this point.
    Wife's car seat took all of a minute to install in her car, mine took an extra 20 minutes trying to figure out this additional stuff. Hope I can save someone else some time.
  18. Aug 21, 2013 at 9:25 AM
    jp05
    jp05 Well-Known Member
    Juan
    TN 931
    2016 Tacoma SR, DCSB, 4x4, Leer Top.
    my car seat goes in there the same way luke's did. I have an 05 access cab. The only difference is that I open the bottom seat portion on the truck. It just gives you more of a flat suface for the car seat to sit rather than having it hang off the front. if anyone wants a pick let me know.
  19. Mar 8, 2020 at 8:03 PM
    mommamanda
    mommamanda New Member
    05 toyota tacoma access cab
    This is a pretty old thread. I use to use the trick on my older car seat with back tracking the tether so it'll actually fit through the tether router... NOW I got a new Diono and its so strong and amazing... I can't do that anymore. It won't detach and the tether won't fit through the router... Any help would be great... Maybe I"ll have to put the car seat in the front seat now..? Help!
  20. Mar 8, 2020 at 8:15 PM
    eon_blue
    eon_blue Most Improved Member
