Help asap please
Discussion in 'Long Travel Suspension' started by 04LTtacoma, Feb 16, 2011.
  1. Feb 16, 2011 at 6:12 PM
    04LTtacoma
    04LTtacoma [OP] Well-Known Member
    Oregon
    So I have noticed that my front tires tilt inward. I am not sure if this is an alignment problem or my upper ball joints might be busted... I have had several alignments done on the vehicle, but I can't eliminate the tires from tilting inward like these pictures. Could it be a upper ball joints? I noticed when i was replacing lower ball joints and a front drive axle the underside of the upper ball joint had a small chunk of metal missing. I am not sure which side it was though. I have jumped the truck several times before. Here is the pics.
  2. Feb 16, 2011 at 6:34 PM
    04LTtacoma
    Oregon
  3. Feb 16, 2011 at 6:44 PM
    98tacoma27
    Ben
    Not Beech Creek
    Are the UCA's stock?
  4. Feb 16, 2011 at 7:00 PM
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    Oswego is right. Inspect everything closely and if you dont turn anything up then pull it apart for a better inspection.
  5. Feb 16, 2011 at 8:55 PM
    04LTtacoma
    Oregon
    Yeah, I might have bent my UCA's and no the UCA's are not stock... This isn't good! Haha
  6. Feb 16, 2011 at 9:22 PM
    04LTtacoma
    Oregon
  7. Feb 16, 2011 at 9:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    On an LT front end???? Youve been drinking again....right?
  8. Feb 16, 2011 at 9:24 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    :rofl:
  9. Feb 16, 2011 at 9:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No need for a "Bump" until you do what these guyz said
  10. Feb 16, 2011 at 9:31 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Spindles are the first place to look after you get alignment specs. Looks like you might have just hit it out of camber. How long has it been like this?
  11. Feb 16, 2011 at 9:33 PM
    04LTtacoma
    Oregon
    For a month or so. Alignment only helps with toe not camber. That is it I will get another alignment done and see what happens.
  12. Feb 16, 2011 at 9:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I dont see how you could have bent the UCA's. THe Spindles, but not the UCA's.
  13. Feb 16, 2011 at 9:34 PM
    04LTtacoma
    Oregon
    :rofl:Hahaha
    I can't do anything at the moment. It is fricken 10pm here. lol
  14. Feb 16, 2011 at 9:35 PM
    snowgod06
    Rob
    06 Access Cab
    actually its 935pm lol
  15. Feb 16, 2011 at 9:35 PM
    04LTtacoma
    Oregon
    okay... Spindles are hard to find at junk yards. Brand new is going to cost me an arm and leg. This sucks! lol Those TC gussets didn't do anything for the truck.
  16. Feb 16, 2011 at 9:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL! Yeah, I see Oli beat me too...I was answering a PM, so I guess I was late to the party :eek:
  17. Feb 16, 2011 at 9:36 PM
    04LTtacoma
    Oregon
    I was rounding up fool:p
  18. Feb 16, 2011 at 9:38 PM
    08pretaco
    az
    You have a flashlight right?
    TC spindle gussets or the uca gussets?
  19. Feb 16, 2011 at 9:52 PM
    04LTtacoma
    Oregon
    I have the TC gussets. They were welded on to mu stock spindles.
  20. Feb 16, 2011 at 9:54 PM
    04LTtacoma
    Oregon
