Help ASAP! Stuck in 4WD!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SteveB313, Jul 21, 2018.
  1. Jul 21, 2018 at 7:21 PM
    #61
    SteveB313
    SteveB313 [OP] Well-Known Member
    Detroit
    20 Tacoma TRD OR blackout/MGM, dbl-cab, AT3W’s
    No the whirring occurs regardless of movement. Even just standing-N into R or D it makes that noise. I tried rolling 4H to 2WD and it just blinks. I can get it into 4L no problem, coming back out to 4H while standing to avoid the noise requires power-off, knob to 4H, power on, D, but it just stays in it, never makes it to 2WD, endlessly blinks.
  2. Jul 21, 2018 at 7:21 PM
    #62
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    Not many options (read NONE) for a mid size truck with a stick shift. :annoyed:
    I am fixing my 93 with manual shifters to enjoy the reliability :burnrubber:
    hiPSI[QUOTED] likes this.
  3. Jul 21, 2018 at 7:24 PM
    #63
    avw4x4
    avw4x4 Well-Hung Member
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    I don’t know about the third gen trucks, but they are presumably similar to the second. My second gen had the t-case actuator crap out and you could get it into 4wd high/low range by taking a cover off and spinning some plastic gear on the back of the tcase. You could try that and see if it gets you out of 4wd or just pop the front drIveshaft off.
  4. Jul 21, 2018 at 7:30 PM
    #64
    The-Stig
    The-Stig Well-Known Member
    Kyle
    2017 TRD Off Road / Access Cab / Long Bed
    I mean that could have caused the initial problem.
  5. Jul 21, 2018 at 7:37 PM
    #65
    SteveB313
    Detroit
    May have somehow, but I followed the steps to the word, literally had my gal reading it to me shot-gun as I rarely use it. We both have been wtf-ing it since then.
  6. Jul 21, 2018 at 7:41 PM
    #66
    The-Stig
    Kyle
    When moving from 4Lo to 4Hi or from 4Hi to 4Lo, you must be in Neutral or Park, and the wheels must not be spinning at all. If you're rolling, it can cause issues.
  7. Jul 21, 2018 at 7:59 PM
    #67
    SteveB313
    Detroit
    Lets say there’s an issue somehow, range of transfer case is spaghetti to actuator just stuck, regardless that I did everything per manual, if it gets to a dealer, how near or far am I from them just getting it into 2WD so I can continue my trip? Can they just unhinge the damn thing?
  8. Jul 21, 2018 at 8:19 PM
    #68
    markmizzou
    markmizzou Well-Known Member
    Mark
    Missouri
    17 SR5 V6 4x4 AC AT tow pkg. Blue as they come
    A back step for when I get older, Carhartt seatcovers, 4Runner wheels, Topper, and "tats all folks"! --for now!!
    from his signature --looks like he drives 2!!??
  9. Jul 21, 2018 at 8:59 PM
    #69
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    That's what many have already said in this thread... remove your front driveshaft. That makes it a 2WD.
    doublethebass likes this.
  10. Jul 21, 2018 at 9:04 PM
    #70
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    I wonder if this happens to MT Tacomas.
  11. Jul 21, 2018 at 9:04 PM
    #71
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    If you need to, you can manually (electrically override) the front ADD actuator to disengage, which means the truck will act like it is in 2wd.
    You get to the front ADD connector (6 pins), and apply about 4 or 5 volts to pin 1 and 2. (I dont recall which way is positive and negative.
    Note, this runs the actuator past it's intended range of motion and causes open circuits on the feedback pots, so when you are done using the override, run the actuator back into a mid position.
    SteveB313[OP] likes this.
  12. Jul 21, 2018 at 9:10 PM
    #72
    MandosTaco
    MandosTaco Well-Known Member
    Armando
    Redding, CA
    2017 Tacoma TRD Off Road DCLB - Blue Pearl
    TRD Pro Fox takeoffs; Wescott TRD Pro lift; ATW4 285's Method 703 -12 offset; TacomaGrilles; OEM bed mat; tailgate vinyl decals; recovery hitch receiver; Subaru Tweeters and Kicker speaker upgrade; derped badges; CoverKing neoprene seat covers; cool stickers and rad patches!
    If you did damage the transfer case when first trying to disengage 4L, then you'll need to get it replaced. I doubt that would be a quick job at a dealer. Probably looking at a few days...
  13. Jul 22, 2018 at 1:53 AM
    #73
    SteveB313
    Detroit
    A dealer would just do that? This is a lease with only 4k, I’m not touching it, it’d entirely be a tech.
  14. Jul 22, 2018 at 4:12 AM
    #74
    SD Quicksand
    SD Quicksand Well-Known Member
    Alex
    San Diego, CA.
    2017 Tacoma TRD Off Road 4x4 Access Cab Quicksand
    I had the exact same thing happen to my 2017 TRD OR. Toyota ended up replacing the actuator and two forks in the transfer case. The parts had to be ordered, so the job took about a week and a half.
  15. Jul 22, 2018 at 4:27 AM
    #75
    Clearwater Bill
    Billy
    Largo Florida
    Doesn't Toyota have a 24 hr roadside assistance as part of your warranty program?
    Let them come and get it. And provide you a loaner while they fix it.
    If they tell you it's going to be a while, continue on with your trip and come back and get it later.
    Or ask them to remove the front shaft, give you paperwork, and let your home dealer complete the repair later. (Your home dealer might want to see the paperwork just to know that you didn't attempt the repair)
  16. Jul 22, 2018 at 4:42 AM
    #76
    bajatacoguy
    bajatacoguy Well-Known Member
    Johnny
    RI to NH
    Blk Taco
    OEM: Bed Mat Roof Rack Tri-Fold Tonneau Cover Door Sill Protectors KO2's Dobinson GTS Suspension TRD Beadlocks Timbren Bump Stops SPC UCA Rear SuperSpring SSO Slimline Winch Bumper SmittyBilt x20 Mobtown Sliders Mobtown Front Skid Avid Basket Bed Rack DECKED Draw Organizer Total Chaos Bed Stiffners Relentless Fab Bed Corner Tie Downs CBI Ditch Light Brackets ARB Dual Compressor Instant Air Tank Smittybilt RTT Road Shower II Indel-B Fridge/Freezer w/ Slide Ironman 4x4 Insulated Fridge Case Redline Tuning Hood QuickLIFT Yo_Hec - Center Console Molle Little Johnny III CB Radio KB Voodoo Flashlight Kit Switch Pro 8100 BlueSea Fuse Pelfreybilt Fuse Panel Mount Gecko - LED Bed Lights Gecko - LED Hood Lights Raptor Grill Lights Cali Raised - Bed Flag Pole Holder Center Console Tray & Organizer Weather Tech Floor Mats Weather Tech Hood Deflector TRAILER BUILD HAPPENING! Plate: Negan
    if all that is worth doing major damage to your truck you have your answer.
    the adult thing to do is get the problem addressed and then move forward with your plans.
    hiPSI likes this.
  17. Jul 22, 2018 at 6:12 AM
    #77
    SteveB313
    Detroit
    Mega update! : after a good night’s rest (both me and the truck) I sauntered out to it with phone in hand ready to call for a tow, fired it up, turned it to 2WD, threw it in gear, let off the brake down the drive (drumroll) the light went out and it’s back in 2!! I wanted to do donuts!
    I’m still taking her in but of it’s own volition this time, I want assurance from Toyota that there’s not something else, plus I don’t have the guts to move it back out of 2 til then.
    remgu2000, U-bolt, Markcal and 6 others like this.
  18. Jul 22, 2018 at 6:17 AM
    #78
    Mojlnir
    Mojlnir Well-Known Member
    Parker, CO
    2018 SR ACLB Utility Pkg
    That's good news!
  19. Jul 22, 2018 at 6:17 AM
    #79
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Just needed a hard reboot! :D
  20. Jul 22, 2018 at 7:46 AM
    #80
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    ADD got wet and need time to dry out.
    melikeymy beer and SteveB313[OP] like this.
