HELP ASAP truck jerks violently
Discussion in '2nd Gen. Tacomas (2005-2015)' started by j83soldier, Feb 25, 2011.
  1. Feb 25, 2011 at 4:27 PM
    j83soldier
    j83soldier [OP] Well-Known Member
    joshua
    Colorado
    05 tacoma
    anti lock brake disable mod, fogtime anytime mod, Leer Topper, all pro plate bumper, toytec 3 inch lift, bfg AT, rims, piaa 5100's, some double din head unit (cant remember), warn 8000 winch, DO sliders, hacked frame to fit full size spare, thule and yakima roof racks
    As stated, my truck jerks violently when shifting gears, more in first but in other gears too. Also sometimes in first it skips 2 or 3 times till I let off the gas. I felt the problem occasionaly earlier in the week but today it is constant. Any suggestions. I am taking it in tommorrow but want some ideas so I dont get raped
  2. Feb 25, 2011 at 4:36 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    ask about the transmission TSB. It changes shifting qualities in the auto trans and should help with your problem
  3. Feb 25, 2011 at 4:43 PM
    Pannell_Trd
    Pannell_Trd Well-Known Member
    Tyler
    Georgia
    2009 Prerunner Double Cab Trd Sport
    Yellow foglights 20% tint
    i agree, when i bought my truck it had the same problem, took it to the dealer and it fixed everything.
  4. Feb 25, 2011 at 4:50 PM
    gregp
    gregp Well-Known Member
    MA
    '13 V-6 4x4
    Is the TSB for only 6 speeds?
    Edit: Sorry, I see you guys are talking about automatics.
  5. Feb 25, 2011 at 4:52 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    tranny TSB they are talking about is for auto only
  6. Feb 25, 2011 at 4:54 PM
    98tacoma27
    Ben
    Not Beech Creek
    Seeing how this truck is six years old and the problem just arose, I doubt it has to do with the TSB. Almost sounds like a u-joint
  7. Feb 25, 2011 at 4:54 PM
    Pannell_Trd
    Tyler
    Georgia
    I haven't heard of any tsb or problems with the 6-speed.
  8. Feb 25, 2011 at 4:57 PM
    The_Hodge
    SC
    throw out bearing TSB for the 6-speeds
    OP, are you a prerunner or 4wd? if 4wd and the u-joints havent been lubed like they should, this might pop the issue that someone saif before. if you are a prerunner, same issue, but they are not greasable on yours.
  9. Feb 25, 2011 at 7:00 PM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    Hmm strange problem. U joints you think eh?
    I would think a servo or valve body junk.
    There's a TSB on the throwout? Oh yea. Why did they publish that? "customer complains of throwout bearing noise, replace throwout." THanks Toyota, i'm sure your technicians couldn't swing that logic jump without a special bulletin.
  10. Feb 26, 2011 at 2:23 PM
    j83soldier
    joshua
    Colorado
    05 tacoma
    well took it in, it is the rear diff. guy said it keeps tring to lock up while driving. The took the diff apart and one of gears is missing 4 teeth. WTF would cause that. I dont wheel, I drive conservably in the truck. Any suggestions
