Help asap with A arm problem
Discussion in 'Suspension' started by wohi, Oct 25, 2007.
  1. Oct 25, 2007 at 3:44 PM
    wohi
    wohi [OP] New Member
    02 4door 4x4 5"tough country lift
    5" tough country lift with front leveling kit.Stock A arms
    Hey everone hope you can help.I bought a used 02 4x4 tacoma with a 5" tough country lift already installed which also has a leveling kit on it. My problem is the ball joint on the upper A arm bends and hits the front spring and stays locked in that position. I asked the local guy at a 4 wheeldrive shop about it and he said I have to replace the upper A arms with new ones that have uniballs. Before I do this want to make sure he knows what he's talking about. Also is there any other solution to this problem? Thanks for the help in advance.
  2. Oct 25, 2007 at 5:12 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    That sounds reasonable. Either that or do a diff drop or say good bye to your ball joints every few months.
