Help:Auxbeam Switch panel and arb compressor
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gsingh916, Jan 9, 2020.
  1. Jan 9, 2020 at 10:01 PM
    Gsingh916
    Gsingh916 [OP] Well-Known Member
    2019 Toyota Tacoma trd Offroad
    so I have a auxbeam switch panel that I want to run a single arb compressor off of. Has anyone done this mod or is it possible
  2. Feb 17, 2020 at 11:35 AM
    hellfire0480
    hellfire0480 Well-Known Member
    Long Island
    2019 TRD OR Quicksand
    Eibach Pro lift, MR701, 285/70R17 AT3W, SOS Sliders, Sherpa RR
    The auxbeam switch panel has a max channel amp draw of 30 amps. Here is the technical data for the ARB compressors. https://www.arb.com.au/assets/air-lockers/6-07.pdf Looks like the amp draw at max would trip that 30 amp breaker. That being said you're not going to be airing up your tires to 100 psi. I've seen others use the compressor on a 30 amp circuit like the switch pro 9100 just fine.
    Maybe others will chime in but I imagine you'd be fine. Are you using for airing up tires? If so may just wire the switch into the engine bay area since you'll have to access the area to hook up an airline.
  3. Feb 17, 2020 at 11:41 AM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    You should be fine! I have the same switch panel just haven't hooked it up yet. I can tell you it is a solid piece of equipment. I highly doubt you'll even use 50 psi. Most ive aired mine up too in 40 with zero issues on amp draw.
    shane100700 likes this.
  4. Feb 17, 2020 at 11:44 AM
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Depends which ARB you go with. If the one you want to use draws more then 30A, use the tigger output to trigger a separate relay instead of the accessory itself. Let a separate relay trigger the ARB.
  5. Feb 17, 2020 at 11:51 AM
    hellfire0480
    Long Island
    Great suggestion to use the switch panel as a trigger.
    I was going off OPs statement that he was using an ARB single compressor so I assumed it was the CKMA12.
    shane100700[QUOTED] likes this.
  6. Feb 17, 2020 at 11:55 AM
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Thank you sir. Yeah I wasn’t sure. Personally if I ever did OBA, I think I’d just do a direct line (fused) to a switch under the hood or in the bed. Likely I’d have to get to that area to plug in or pull out an air hose anyways.
    hellfire0480[QUOTED] likes this.
  7. Feb 17, 2020 at 12:03 PM
    Gsingh916
    Thanks for the info guys but I got it to work I still have the arb hooked up to the battery with a relay and fuse I just connected the switch wire to the auxbeam works perfectly fine
    GreenTaco415, MJTH and shane100700 like this.
  8. Feb 18, 2020 at 5:02 PM
    dc2’s
    dc2’s Well-Known Member
    California
    2017 Toyota Tacoma trd 4x4 off road
    Added a driver
    How do you like it and how do you have it mounted?
  9. Feb 18, 2020 at 6:52 PM
    Gsingh916
    I love it for the price it’s at. I have 42 inch cali raised 30 inch Baja designs, Baja designs s2 sport and the arb compressor wired to it... I have it mounted where the cubby hole was with some 3m sticky tape
    Gnarman, ohcjam, DR TACO and 2 others like this.
  10. Feb 18, 2020 at 7:24 PM
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Any issues with the aux lights flashing on for a split second when you start the truck? I’ve heard that was an issue for guys running the McTuning ones.
  11. Feb 18, 2020 at 7:58 PM
    dc2’s
    California
    Added a driver
    Thank you so much! It’s look awesome!!
  12. Feb 18, 2020 at 9:31 PM
    Gsingh916
    Never had that issue
  13. Nov 14, 2020 at 5:09 PM
    Gnarman
    Gnarman Well-Known Member
    Southwest
    2016 dbcb trd off road quicksand lb
    ARB Shell, BP51, 255/85/16 ST MAXX, SCS Ray 10 Matte Bronze, Caliraised led 32 inch/side shooter/amber pods, floor mats, start x remote start, auxbeam 8 gang switch panel, diode dynamics hid lows, Australian Shepherd
  14. Nov 14, 2020 at 6:58 PM
    Gnarman
    Southwest
    Can you take pics of how you wired things in the engine bay? Looks awesome!
  15. Nov 24, 2020 at 2:15 PM
    Birdog
    Birdog Well-Known Member
    West Coast, Valley Boy
    1st Gen Taco 4x4 SR-5 13th one off the line in Santa Clara May 13 1995. Many mods to it, still showing her force.
    K&N Filter, Boral Exhaust, Posi Trac, CBI DIY front Bumper, Mod front grill, Mod HD lites, Icons mod Front, Rear, & Stero System 7 inch Alpine, with mic, and USB, ipod,, New Carpet, New Suntop Camper shell, Carpet kit rear, Yak roof rack, Rola Cargo basket, Rock Lights,
    Did you use the ARB CMK12 wire harness. Which wire/color did you connect from the ARB to the Auxbeam pos+ wire. Ready to pull the trigger on a 6 panel/Blue ;)
  16. Mar 19, 2021 at 7:48 AM
    18Inferno
    18Inferno Well-Known Member
    2018 TRD-Off Road DCLB Inferno
    How are your aux beam panels holding up?
  17. May 14, 2021 at 4:19 AM
    joeto3
    joeto3 Member
    Which wires on the arb harness did you use to trigger the relay?
  18. Jun 3, 2021 at 6:01 AM
    508Tacoma
    508Tacoma Well-Known Member
    MA
    2017 TRD OR 4x4 DCSB
    @Gsingh916 Any chance of showing some install pictures. Hoping to connect to my Auxbeam panel in the coming months.
  19. Jun 3, 2021 at 6:19 AM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    The red wire from the pressure switch needs the switched 12V.
    joeto3[QUOTED] likes this.
  20. Jun 6, 2021 at 9:47 PM
    iLLFadedBowl
    iLLFadedBowl Well-Known Member
    2019 Super White TRD Offroad Tacoma
    Remote start w/ vehicle control and locator, Prinsu rack w/ Cali Raised Light Bar and 360 LED lights, LED Bedlights, Tailgate lock, 3" Lift, Wheels and Tires, Raptor Lights, LED headlights and fog lights, Blacked out LED taillights, Front windshield eyebrow tint, Rough country bed molle, 8-gang switch to control LEDS, Dominator D6 running boards/side steps, Blacked out sequential mirror turn signals
    Here is a bad picture of mine. Definitely recommend a power tray to keep things more organized. I installed mine on the passenger side because there is more room and I dont have any plans of adding a second battery. Had to do a little modification to the power tray to get it to work on the passenger side. Still need to clean in up a little and add some loom over the wires running along the firewall. Let me know if you have and questions.20210605_170930.jpg 20210605_170755.jpg
