Help:Auxbeam Switch panel and arb compressor
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gsingh916, Jan 9, 2020.
  1. Aug 8, 2021 at 10:17 AM
    joeto3
    joeto3 Member
    I have the same setup and absolutely hate the arb harness.
    Anyone have a diagram of how to wire this up?
    k_j_souv likes this.
  2. Aug 8, 2021 at 10:24 AM
    joeto3
    joeto3 Member
    Will try this out and hopefully it works!
  3. Sep 29, 2021 at 11:29 PM
    joeto3
    joeto3 Member
    Just in case someone wants to install an ARB compressor to their vehicle with any auxiliary relay system.
    If you're only installing the ARB compressor, and don't mind splicing the included ARB cable, the 4 prong connector (that isn't connected by default) has a purple wire that is for the compressor activation.
    Then you just need to connect the (2 thick red wires) to battery + (1x thick black wire + 1x thin black wire) to ground.
    Lastly, power the activation switch by connecting the purple wire to a 15A fuse. ARB's included switch is rated for 15A, so it's on a 15A fuse (photo shows 20A, but it's on a 15A).
    Lastly, as per ARB's instructions, here is the same plug that I marked in green in the photo above, and with their instructions.
    The wire loom I have connecting to the relay system can be purchased here, and includes the correct wire colors (purple wire, instead of red).
    Blue arrow is where the purple wire leads to.
    Tldr: plug in purple wire from 4 prong wiring harness to activate compressor. This is the 12v compressor activation
  4. Dec 1, 2021 at 2:16 PM
    tacoma08brandon87
    tacoma08brandon87 Well-Known Member
    brandon
    El Paso Texas
    TRD
    I have the same switch panel. I have dual air compressor that I want to connect it would I be ok.?
  5. Dec 1, 2021 at 3:31 PM
    tacoma08brandon87
    brandon
    El Paso Texas
    TRD
    I have a question need help with I have dual arb twin air compressor that I want to hook up to the switch panel. Is it possible
  6. Dec 1, 2021 at 6:44 PM
    joeto3
    joeto3 Member
    You need to splice it, or get a $20 cable from someone. Couldn't find the connector after an hour of searching on mouser.
  7. Jan 5, 2022 at 11:11 AM
    atlas99
    atlas99 Well-Known Member
    Cody
    Washington
    17' SR5 DCSB
    A different route and what I did with my ARB Twin/Auxbeam panel: If you don't plan on running airlockers (therefore don't need actuators) then you don't need three switches and you don't need to splice, you can cut before the "PLUG-IN FITTING" labeled in the image from joeto3 post. Then purple wire to positive/black to negative, wire up to the battery as you would normally and you're good to go.
  8. Jan 5, 2022 at 11:18 AM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    I have this switch and the ARB Twin works great! Really easy to set everything up.
  9. Jan 5, 2022 at 11:25 AM
    tacoma08brandon87
    brandon
    El Paso Texas
    TRD
    Fuck I didn’t run it to the switch panel people were saying that it can burn it out
  10. Jan 5, 2022 at 11:27 AM
    atlas99
    Cody
    Washington
    17' SR5 DCSB
    Rip, yeah I have been running it like this for years with no issues. They are probably referring to powering the compressor and you definitely don't want to run power directly to/through the switch panel for something that big (compressor, winch, etc) but powering the switch is totally fine.
  11. Jan 5, 2022 at 11:30 AM
    tacoma08brandon87
    brandon
    El Paso Texas
    TRD
    I just ran it to its own arb switch by 4x4 is it ar
  12. Jan 5, 2022 at 9:09 PM
    toku58
    Mall Crawler!
    The Auxbeam "switch" only replaces the rocker "switch" all the other wiring stays the same on anything you run.
  13. Jan 11, 2022 at 8:11 AM
    CementTacoSupreme42
    CementTacoSupreme42 Member
    Nic
    2020 cement Tacoma trd off-road
    Following.. I just got my twin compressor and I wanna wire it up to my auxbeam.
  14. Jan 14, 2022 at 11:01 PM
    CementTacoSupreme42
    Nic
    This is extremely helpful
  15. Mar 15, 2022 at 9:32 AM
    #35
    SpyGoat
    SpyGoat I miss you Hobbs
    Tom
    Long Island, NY
    2021 TRD Off Road MGM DCSB, 2025 Land Cruiser
    A bunch..and no build thread!
    Doing the same thing. So, Purple from the connector to pos on the switch power block with a 15amp fuse..and the black (off that same connector) to the ground?
    I already have the battery power leads and ground leads ready to go. Just want to run activation off my auxbeam.
  16. Mar 15, 2022 at 8:18 PM
    #36
    Thejohnnyb21
    Thejohnnyb21 Well-Known Member
    Johnny
    Pasadena, CA
    21' AG Tacoma TRD OR
    Don't remember how I did mine but the wire that activates the relay.. I cut the end and connected the red and black wires to the panel
    SpyGoat[QUOTED] likes this.
  17. Oct 7, 2022 at 12:22 AM
    #37
    GreenTaco415
    GreenTaco415 Work Hard Play Hard
    NorthBay
    22’ Army Green Tacoma TRD SPORT DCLB
    Stumpy DV8 front bumper w/ 20” Rigid light bar, aftermarket front and rear headlights/tail lights, aftermarket fog lights, PRINSU full cab rack w/handles with 40” RIGID light bar, FULL Black TRD SKID PLATE CBI rock sliders w/kickouts, AuxBeam unit for under hood wiring of additional lights etc, Raptor grille lights, Hood/A-pillar pod lights(Amber-RIGID INDUSTRIES), Amber Rock Lights(RIGID INDUSTRIES) , Interior Red Trim inside cab, Blacked Out Badges all over Truck, removed stock Stickers on tail of truck and put TRD PUNISHER EDITION w/Skull stickers on both sides, LIFTED a couple inches over stock from dealership on 31.5” Tires / All black matte rims with RED TRD in center
    This is great that i found this thread! I have all my extra lights on my truck running through my Auxbeam and i recently purchased the single ARB COMP and was wondering if i could run the switch through my AuxBeam unit to keep the additional switches down!!! This makes me pumped to find this out!!
    i have everything in my possession and just waiting on the mounting plate from SLEE and ill be ready to rock and start my install!
    I decided to opt to running lines to all 4 tires so there’s shrader valves at each tire and ill just need short leads to each tire to fill up all at the same time!!! Can’t wait!!
  18. Oct 7, 2022 at 4:07 AM
    #38
    SpyGoat
    Tom
    Long Island, NY
    The info in this thread got me situated! My ARB dual has been running off my Auxbeam since I got the info here, without issue and I use it a lot.
  19. Jul 15, 2023 at 11:30 PM
    #39
    Gmoney15TRD
    Gmoney15TRD Member
    2015 Pyrite Mica TRD Offroad
    Fox 2.5 front 2.0 rear, diff drop, ecgs needle bearing replacement, all pro uppers, carrier bearing drop, 3 leaf aal with shims, extended brake lines, all pro apex front bumper, alpharex headlights.
    That's what I was thinking. That being said. If u used the panel as a switch for a relay and separate fuse. You should be able to hook the relay up to one of the low Amp fuse channels on the panel. Correct?
  20. Jul 16, 2023 at 7:12 AM
    #40
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    yes.
