help! Brake Light bulbs...?
Discussion in 'Lighting' started by Soccerdallin, Mar 14, 2012.
  1. Mar 14, 2012 at 2:42 PM
    Soccerdallin
    Soccerdallin [OP] Well-Known Member
    Dallin
    Arizona
    04 SR5 3.4L V6 4X4
    Magnaflow exhaust w/ tip, 18" Rockstars, AEM CAI, TB Spacer, Billet Grille, Limo tint, LED tail lights, 20,000k HID headlights + Blue LED strips, debadged, Jl Audio Subs in custom box, 6X8 speakers with tweeters, sony deck.
    whaddup guys
    I've tinted my tail lights, but not much. The light is barely dimmed from the tint.
    Although, my truck didn't pass inspection because of my tail lights, the guy that was inspecting said he's been pulled over 5 times due to his tinted tail lights as well....but his must have been darker than mine! I don't want to redo my lights, cause it's a pain.
    I bought these yesterday: http://www.oreillyauto.com/site/c/d...-1_-1&mn=Jam+Strait&mc=JSI&pt=N0383&ppt=C0335
    and they are about the same brightness as the factory bulbs. :/
    I've looked at a bunch of bulbs on Amazon and such, and no auto stores have anything else besides the bulbs I just bought.
    http://www.amazon.com/dp/B000ES867W/ref=asc_df_B000ES867W1936987?smid=A3RM9VXAAYI2BW
    These bulbs apparently aren't as bright either, and the reviews aren't convincing enough to buy them.
    Anyone know of brighter brake bulbs online or anywhere?
    Part number: 1157
    I need to get them asap.
    Thanks.
  2. Mar 14, 2012 at 2:44 PM
    rhion82
    rhion82 El Duderino
    Mitchell
    TN/GA
    16 Taco
  3. Mar 14, 2012 at 7:10 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    2357 will be the same brightness for tails, but the brake light will be a lot brighter.
    No options for brighter tails.
  4. Mar 14, 2012 at 7:27 PM
    elmo7
    elmo7 Easily Replaceable Member
    SC
    07 DC TRD OR 4x4
    So what do they do at inspection? Do they use a light meter to read the output?
    I know it may look cool, but if someone rear ends you, it's their fault....usually. In that accident, if they point out you have brake light mods, you'll likely be at fault.
  5. Mar 14, 2012 at 8:06 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    +1
    Don't fuck with the safety equipment. There's a reason it did not pass inspection and it likely would not pass with 100 watt bulbs simply because it is tinted beyond factory.
  6. Mar 14, 2012 at 11:40 PM
    Hii
    Hii Well-Known Member
    Get CREE LED bulbs
  7. Mar 15, 2012 at 10:55 AM
    Soccerdallin
    Dallin
    Arizona
    04 SR5 3.4L V6 4X4
    Are they noticeably brighter?
  8. Mar 15, 2012 at 9:04 PM
    Hii
    They are the brightest LEDs you will be able to find
