Help braking s are locking up?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Lava-road, Jan 9, 2022.
  1. Jan 9, 2022 at 10:16 AM
    Lava-road
    Lava-road [OP] Well-Known Member
    2019 trd-off road
    Hard top camper...many more to add+
    This morning going up a hill on a tight turn ..rear brakes seen to lock up..put in reverse..it release it.. drove to fill in gas …got in to start the truck…and go….rear brakes lock up…shift gears, reverse and it free again…
    Please what is the problem? How can I fix this problem…
    I will call the dealer on Monday…
    Aloha
    2019 TRD Off Road LB -Auto w/ camper top…
  2. Jan 9, 2022 at 10:18 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Is this your parking brake locking up after parked? Sounds like it
  3. Jan 9, 2022 at 10:19 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Are u lifted?
    shakerhood likes this.
  4. Jan 9, 2022 at 10:21 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    Looks like from his other posts, could be stretched cable?
  5. Jan 9, 2022 at 10:22 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Wet brakes will cause your problem
    Hiluxski likes this.
  6. Jan 9, 2022 at 10:31 AM
    mrcheap
    mrcheap Well-Known Member
    Check collapsed or kinked brake hose
  7. Jan 9, 2022 at 10:44 AM
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    That’s what drum brakes do. That’s why nobody else uses them. Common problem. Are any Tacoma front wheels locking up? No. Or any wrangler rear wheels locking up. No. They have disc brakes
    doublethebass likes this.
  8. Jan 9, 2022 at 10:58 AM
    Lava-road
    2019 trd-off road
    Yes I am lifted 2.5 front 1.5 rear…Bilstein 6100 & 5160 w/ icon add-a-lift 1.5…32 ko2
    Should I get longer brake cables for the rear?
    it this is happen all the time now…two times this morning ..went up the hill to other houses lock up two more times..
    Help please!
    Aloha
  9. Jan 9, 2022 at 11:27 AM
    Cereal_killer
    Cereal_killer Well-Known Member
    Dan
    '18 Off-road, ‘96 V6
    Yeah
    Lol nobody else uses them? Someone doesn’t know shit about actual trucks…
  10. Jan 9, 2022 at 11:32 AM
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    If you have the ability remove your drums and see what's going on. Drums are pretty simple and for the most part reliable. They do require maintenance though. Could be something as simple as a broken spring.
  11. Jan 9, 2022 at 11:39 AM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    Brake cylinder failure is common too and cause lock up.
    Agree with drum brakes being easy. Just open them up and take a look. If there’s brake fluid around the cylinder, it’s needs to be replaced. Chances are you need to do a rear brake job.
  12. Jan 9, 2022 at 11:41 AM
    jake72
    Jake
    N.E. PA
    Sounds like it’s flexing pulling on the brake cables
  13. Jan 9, 2022 at 11:42 AM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    To me sounds like your traction control was just doing it’s job. When you turn, you unload the wheel on the inside of the turn. If that wheel starts to break traction, the ECU will momentarily apply the ABS to that wheel’s brake to prevent wheel spin.
  14. Jan 9, 2022 at 11:54 AM
    Lava-road
    2019 trd-off road
    This happens in crawl control too ..I reverse and frees the rear brakes..did this a few minutes ago…seems to happen more on a sharp right hand turn..but not always..
    In 4 h high …starting to happen very , very often..half a dozen times now from this morning..
    Now sure if I should drive it on the highways?
    The rear brakes seems to lock at stops sometimes…
    I look at all the brake lines …look normal and stock…room for extension when wheel extended..
    Next is call the dealer…have them look at the rear brakes..
    Aloha
    I did read about this problem of rear brakes locking a year ago…not sure how to find it?
    Aloha
  15. Jan 9, 2022 at 1:41 PM
    Lava-road
    2019 trd-off road
    Now it is worst…driving on my dirt road…rear brakes engage automatically…! Now I know I will need a tow to the dealer…calling tomorrow…for sure…
    the more I see all the issues of the Tacoma’s trucks…now I wonder just how good they are…off course every other brands have there’s too..
    this braking problem? Hope they fix it ?
    Guessing when I tested and engage the crawl controls..just yesterday…It might have broken something? Crawl controls only works the brakes and throttle controls…maybe it damage the brakes, springs, or brake cylinder?..
    anyone else had this problem?
    Aloha
  16. Jan 9, 2022 at 3:26 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Are you lifted?
  17. Jan 9, 2022 at 4:17 PM
    Lava-road
    2019 trd-off road
    Yes.. 2.5 with 32 inch tires…Bilstein 6112 and 5160 w/icon add-a-lift 1.5…SPC…
    I am sure the lift may not be the problem…brake lines look OK…
    I did test my crawl control yesterday going down a dirt road…
    The problem started soon after that…. The crawl control may have damage something?
    Looks like not many others had this problem before? We will see what happens at the Toyota dealer…they are busy , May have to schedule ..hopeful sometime this coming week..
    Just that I need a tow…never know when the rear brakes engages…already happening more and more often..driving thru the coffee farm roads.. hopefully it will make it up the hill to the highway..?
    Aloha,
  18. Jan 9, 2022 at 4:58 PM
    dfanonymous
    Its not common. Despite some of the shit talkers, drums are relatively reliable. They really are easy to work on once you do it a few times.
    So, with all respect, there really can only be so many problems with the brake. It’s just kind of hard to speculate without looking in there.
    if you want some reading material.
    https://www.tacomaworld.com/threads/rear-drum-brake-locking-up-after-getting-wet.653123/page-2
    https://www.tacomaworld.com/threads/parking-emergency-brake-seized-stuck.470756/page-5
    https://www.tacomaworld.com/threads/brakes-locking-up-solved.579794/page-2
    RustyGreen likes this.
