HELP--broken coil bolt
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 06aztaco, Mar 16, 2010.
  1. Mar 16, 2010 at 1:30 PM
    06aztaco
    06aztaco [OP] Screw you guys, I'm going home.
    Cole
    Phx AZ
    06 Prerunner 2.7
    I was changing my spark plugs for the first time on my '06 v6 taco this morning and when re-installing a bolt that holds on a coil, the bolt snapped about half way through the threaded area. Any suggestions on how to get it out and get another bolt?
    also thanks chris4x4 for the install instructions.
  2. Mar 16, 2010 at 1:32 PM
    j0sh
    j0sh Well-Known Member
    Oklahoma
    '10 TRD Sport 4x4
    AFE Filter, TRD Catback
  3. Mar 16, 2010 at 1:34 PM
    06aztaco
    Cole
    Phx AZ
    06 Prerunner 2.7
    do you know where to get that besides online? checkers, autozone, etc. for example?
  4. Mar 16, 2010 at 2:21 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    now how did this happen? that is a pretty minor fastener. how did it break?
    is any bit of it sticking out? post up a picture. they make a thin, reverse twist drillbit. since you will need to drill it, may as well drill it backwards. you could get lucky and spin it out.
    SEARS is your friend right now.
  5. Mar 16, 2010 at 2:39 PM
    06aztaco
    Cole
    Phx AZ
    06 Prerunner 2.7
    I was just tightening the bolt down and it snapped. Sorry the pictures are so bad its hard to get in there. Like I said there should be about twice as much thread on the bolt. About one millimeter of the broken part is sticking out. :(
  6. Mar 16, 2010 at 2:45 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    If their is enough of it sticking up you might try some needle nose vice grips.............worked for me before.....................good luck........
  7. Mar 16, 2010 at 2:49 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you may need to cover the spark plug hole with a rag and use a very small drill bit on the broken bolt and try an ez out.
  8. Mar 16, 2010 at 2:49 PM
    aficianado
    back to bone stock.
    1mm isnt alot. i would attack it two ways. do you think it is loose? it isnt bottomed out or under tension...should be loose. unless you xthreaded it, then different problem. if it is loose you can cut a slot in it with a dremel, and back it out with a flat bladescrewdriver.
    or drill it and take it out with a screw extractor. at sears, or any decent hardward store.
  9. Mar 16, 2010 at 2:50 PM
    aficianado
    back to bone stock.
    ^^^yes. EZ outs work great. like this.
  10. Mar 16, 2010 at 2:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    THIS. Very important to cover the spark plug well.
  11. Mar 16, 2010 at 2:56 PM
    Mr_Torque
    Mr_Torque Buy the Ticket take the Ride.....
    Perkasie,PA
    '07 Tacoma SR5 4WD V-6 6 Spd
    MBRP Exhaust, 17" FJ Steelies w/Firestone AT's, Truxedo Lopro ,Timbren SES, Pioneer FH-X720BT HU & TS-C720PRS Component Speakers, TRD Quickshifter, Bilstein 6112/5160, Light Racing UCA, and Icon Progressive add a leaf.
    That is not a good spot to break a bolt. Dry seizing a steel bolt in aluminum is a bitch to remove. First get the coil out of the way and stuff paper towels or a rag in the spark plug hole. If there is any thread sticking out spray it with some penetrating oil and wait for it to soak. Take a steel hammer and give the broken bolt a couple of careful sharp hits. Now take a good pair of vise grips and try to turn the bolt out.
    Unless you're really good at drilling stuff out a would recommend finding someone who has experience. If you screw it up it could get expensive.
    If you don drill make sure to start small...you can always drill bigger. Good luck and don't forget the "Never Sieze".
  12. Mar 16, 2010 at 2:56 PM
    06aztaco
    Cole
    Phx AZ
    06 Prerunner 2.7
    alright thanks guys. anybody know where to get a replacement bolt?
  13. Mar 16, 2010 at 2:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The bolt hole for the coil is steel lined. Odds are, he got it cross threaded, and snapped the bolt.
  14. Mar 16, 2010 at 3:00 PM
    djs05tacoma
    djs05tacoma Well-Known Member
    Martinez, CA
    05 Double Cab TRD offroad 4x4
    3" OME Lift, 285's
    I'v used the flat blade method a few times after breaking a few ez outs. if you go the EZ out method make sure you a get the hole started in the center other wise you might be in trouble, and keep in mind that ez outs are very brittle and easy to break.
    If you've never dealt with the ez out and there is enough bolt sticking out at the top to notch out for a flat blade then I'd suggest trying that method first. If you get a hacksaw blade cut down nice and short and get a good line across that bolt you should probably be ok.
  15. Mar 16, 2010 at 3:05 PM
    Sparky4.0
    Sparky4.0 Well-Known Member
    Aaron
    WestTexas
    01 trd beat to hell
    1 thing no1 has said is to weld the vise grips to the bolt. as it will be a pain in the arse to get a seized steel bolt out of aluminum. but only do this as a last resort!!
  16. Mar 16, 2010 at 3:12 PM
    nuckinfuts
    nuckinfuts NyQuil on the rocks.
    Pacific NW
    '06 AC TRD Off-Road
    DT Long Tube Headers, Empire O2 simulator, catback, Shrockworks Sliders, Old Man Emu 3" lift with 885 coils (with 1/2" top plate spacer and Dakar Leaf packs), Hi-lift mounted in bed with 4XRAC mounts, WT floor liners, other stuffs
    Sounds like you have plenty of options to try. I'd use a piece of tape over the plug hole instead of cramming it full of rags. Also, if you end up going the ez-out route get a center punch to line up that first drill bit in the center of the bolt. Drill slowly and be sure you're drilling it in straight.
  17. Mar 16, 2010 at 3:21 PM
    06aztaco
    Cole
    Phx AZ
    06 Prerunner 2.7
    yeah I should be able to get it out pretty easy. its just on the driver side so all those hoses are in the way unlike the passenger side. so no suggestions on a replacement bolt?
  18. Mar 16, 2010 at 3:24 PM
    nuckinfuts
    Pacific NW
    '06 AC TRD Off-Road
    Take one of the other coil bolts out (without breaking it) and use it to size a new bolt at the auto parts store or local hardware store. Ideally you would go to the dealer and pick up the 'correct' bolt.
  19. Mar 16, 2010 at 3:25 PM
    Taco John
    Taco John Well-Known Member
    Illinois
    4X4
    Take one of the good ones to your local Ace, True Value, etc. They can probably set you up. If not, off to the dealership!
  20. Mar 16, 2010 at 3:29 PM
    Sparky4.0
    Aaron
    WestTexas
    01 trd beat to hell
    the stealership would be your best bet on a replacement bolt. yotas use alot of uncommon thread pitchs on there bolts.
