HELP!! Calling all Electrical/Lighting buffs!
Discussion in 'Lighting' started by AstroluxAtom, May 4, 2012.
  1. May 4, 2012 at 12:34 PM
    AstroluxAtom
    AstroluxAtom [OP] Well-Known Member
    Sunnyvale, California
    '05 v6 4.0L DCSB Offroad Prerunner Debadged
    3" Pro-Comp lift kit, Pro-Comp Tires, Magnaflow exhaust dumped at rear axle.
    Back in march, I did the fog light anytime mod, and the DTRL mod using the quick splice method provided by board user Piercedtiger (http://www.tacomaworld.com/forum/technical-chat/4838-cheap-free-mods.html#post45435). The Side markers and DTRL's worked fine up until I noticed them today while pulling into a bank of america. Neither the side marker or the DTRL's will turn on, and my interior orange backlight is ALWAYS on whether the switch is off, on side markers, or headlights. I loved having the side markers and DTRL's on all the time, so could this be a reason they stopped working? My blinkers and hazards still work perfectly fine, so I am guessing it has to do something with the DTRL mod, but how do I fix this?? Pretty bummed out...I hope I didn't fry anything that is too intricate for me to fix on my own!! If anyone has any advice, please shoot it my way so I don't bring it to the goddamn stealership.
  2. May 4, 2012 at 12:35 PM
    11TRD
    11TRD MERICA
    Jay
    Everett, WA
    2011 TRD SPORT 4X4 DC
    Cobra 29 WXNWBT, Devil Horns, ARB Bumper, Avid Stepbars, Homer Taco Satoshi thin lip grille, ICON UCA's, ICON EXT Travel up front with King 700# springs, Dakar heavy springs, sumo bump stops, with ICON VS 2.0 shocks in the rear, K&N Drop In, AVS Ventshades and Bugflector, Whelen SPS 660 emergency strobes, Redline Hood struts and tailgate EZdown, Illuminated 4X4 Switch, TRD Floor mats, Flyzeye LED lighting, Kragen 7" HID behind grille, Kragen 4" HID back up lights, Rigid SR Series 10" LEDx2 Elusive elements Lightbar, Firestik antenna, Rear Diff breather mod, Fogs anytime, Hitch Safe, OEM door sill strips, mryo mirror relocate bracket, Prinsu designs roof rack, Tepui Autana RTT, ARB Awning,Engo 10k winch synthetic, Blue seas fuse block and breaker, ARE Topper
    :popcorn:
    Subd
  3. May 4, 2012 at 12:38 PM
    11TRD
    11TRD MERICA
    Jay
    Everett, WA
    How many times did you post this???
  4. May 4, 2012 at 12:38 PM
    scocar
    scocar hypotenoper
    Dude, you have posted the same thread in three different forums within minutes. What the hell? Just leave the one in lighting and have the other two deleted.
  5. May 4, 2012 at 12:39 PM
    medusa1066
    medusa1066 Well-Known Member
    Jonathan
    Morgantown, WV
    2007 4x4 TRD Sport
    Worst Case, can't u just reverse the installation to get back to stock?
  6. May 4, 2012 at 12:41 PM
    98tacoma27
    Ben
    Not Beech Creek
    You guys are :crazy:
    :drevil:
  7. May 4, 2012 at 12:46 PM
    scocar
    scocar hypotenoper
    yur mai faveret janiter :thumbsup:
  8. May 4, 2012 at 12:47 PM
    98tacoma27
    Ben
    Not Beech Creek
    I model my life after him...sans the squirrel army.
  9. May 4, 2012 at 1:59 PM
    11TRD
    11TRD MERICA
    Jay
    Everett, WA
    Did you say Squirrel?!?!?! :goingcrazy:
  10. May 5, 2012 at 1:31 PM
    AstroluxAtom
  11. May 5, 2012 at 1:32 PM
    98tacoma27
    Ben
    Not Beech Creek
    Did you try reversing it yet?
  12. May 5, 2012 at 1:37 PM
    AstroluxAtom
    Nope...I was hoping someone would chime in a repair, not a reversal =( Might just have to go that route though. Although im still confused as to why the orange backlight stays on! grr.
  13. May 5, 2012 at 1:47 PM
    98tacoma27
    Ben
    Not Beech Creek
    The issue is it's almost impossible to diagnose on description only. Since it worked before, it's possible that a wire connection came undone and is touching something it shouldn't be. You might get more responses if you post pictures of the wiring connections. Reversing it (even if temporarily) is just going to prove it's the mod and not something else.
  14. May 8, 2012 at 3:08 PM
    AstroluxAtom
    So I checked my owners manual and it pointed to a fuse being out. Sure enough it was. Replaced the fuse and they worked fine until I started the car...then it blew again. I changed to a 15A and yet again the fuse blew. Looks like i'll be reversing the mod temporarily until me or (hopefully) someone on here figures out a remedy. What is throwing me off is the fact that they worked fine for over a month! Input please!!
  15. May 8, 2012 at 9:32 PM
    joes06tacoma
    Joe
    Central Coast, CA
    You have a short to ground somewhere in the circuit that the fuse is feeding. It wasn't there when you did the mod, so I don't think the mod is the reason.
    First thing you do is go back and double check every single little detail of what you did to perform the mod. This kind of thing tends to be something stupid, like a wire pulled tight on a sharp metal edge, that finally rubbed through after a month.:)
  16. May 9, 2012 at 5:41 PM
    AstroluxAtom
    Went through and found that the wire next to the green blinker wire had become smashed a bit from who knows what, and a small amount of copper wire was exposed. I covered with electrical tape and added a new fuse, and POP. The problem is still there. Running out of ideas here. I am going to be so mad if I undo the mod and the fuses keep blowing.
  17. May 10, 2012 at 1:07 PM
    AstroluxAtom
    DAMN. DTRL mod undone and still get the blown 10A fuse #27. Off to the stealership. Why me?
