Help!!! Cant get my lights out!!!
Discussion in 'Lighting' started by nicholism, Aug 22, 2009.
  1. Aug 22, 2009 at 6:07 PM
    nicholism
    nicholism [OP] New Member
    little rock, ar
    09 PreRunner SR5 DCab
    Hey everybody. I Just got some AWESOME aftermarket projector headlights. The problem is that I can't get the damn OEM lights out! I've read all of the previous posts and spent a considerable amount of time under the truck. I've found and removed all of the screws and plastic pins, but i can't seem to get the bottom bolt out - the one that you have to get at from under the truck. I've located it, but no wrench seems to get a good grip on it. What size socket wrench should I use, and do any of you have any helpful suggestions? Thanks so much for the help!
  2. Aug 22, 2009 at 6:11 PM
    ccoorreeyy
    ccoorreeyy www.EvolvedFinance.com
    Corey
    Los Angeles (South Bay)
    08 Double Cab 4x4 SR5 Debadged
    BHLM, Revenge Fab Rock-Sliders, BFG TA KO's, N-Fab light bar with 4 Hella 500's, Rear Suspension TSB, TRD Exhaust, CB Radio, 100W Ultra bright headlights, JBL Sound
    Look up the BHLM. There's some pretty detailed instructions on how to remove. I remember it being the heardest part, but once you figure it out, it's pretty easy.
    I think the bolt is 13mm but don't quote me. Just try it. :D
    Good luck!
  3. Aug 22, 2009 at 6:12 PM
    ccoorreeyy
    Corey
  4. Aug 22, 2009 at 8:10 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    It's just a 10mm bolt. Use a small ratchet to loosen it until you can do the rest with your fingers.
