Help choosing injectors please
Discussion in '1st Gen. Tacomas (1995-2004)' started by rybern, Nov 19, 2017.
  1. Nov 19, 2017 at 1:26 PM
    rybern
    rybern [OP] Well-Known Member
    N Alabama
    2023 TRD OR & 2000 SR5
    5100's & 3AAL, 265/70r17 Toyo AT3
    I have the complete intake removed from my 2000 3rz and have decided that it's a good time to replenish my injectors. At first, I thought I would just send them to InjectorRX and let them clean and flow test them. But then a fellow board member suggested some "pink tops" for better flow and spray pattern. I've researched pink tops and don't really find much info. According to my VIN, my injectors are 23209-79095. If someone can confirm pink top part numbers, that would be great.
    Please let me know if you have any other suggestions. Thanks.
    Option 1:
    I found these on Ebay that claim to be genuine Denso 23209-79095 plugs at a great price. I'm a bit concerned about them being so cheap and I won't benefit from the improved flow of the new injector:
    https://www.ebay.com/itm/OEM-4x-Fue...ash=item3ad5264f6b:g:QcQAAOSw6DtYWhiu&vxp=mtr
    Option 2:
    I see some injectors on Ebay that are OEM pink tops and show to work with my motor, but they look taller and I'm concerned that the mounting for the fuel rails wont work. The numbers on them also lead me to believe that they are the Cali versions. Here's the link:
    https://www.ebay.com/itm/OEM-Fuel-Injectors-For-Toyota-4Runner-Tacoma-2-7-2-4-L4-23209-79135-23250-75080/202079113477?fits=Model:Tacoma&hash=item2f0cda9105:g:eek:J0AAOSwLnBX3K58&vxp=mtr
    Option 3:
    Send my OEM injectors to InjectorRX and have them cleaned/flow tested. Safe bet, but I'd be missing out on the upgraded flow pattern.
  2. Nov 19, 2017 at 1:28 PM
    Speedytech7
    ゼイン
    5520 E Sprague Ave, Spokane Valley, WA 99212
    93 80 Series LC & 96 Turbo V6 Taco 4WD
    I've done a mod or two
    I have a set of pink tops, you can find them in 01-04 3RZ and 2RZ engines, they have an improved spray pattern and higher flow potential. Still need to get mine cleaned and flow tested though. Pink tops are skinnier but they are dimensionally the same height after o ring and such are on.
  3. Nov 19, 2017 at 1:36 PM
    rybern
    N Alabama
    Ah, so they will really just plug in and the rails bolt right on then? They just look like they are taller?
    I've heard that a set can be purchased for ~$100 but haven't seen any quite that low.
  4. Nov 19, 2017 at 1:39 PM
    Speedytech7
    ゼイン
    They're out there, I got mine for $50 shipped. Look at the part outs in the Buy Sell and Trade threads, lots of people part out rather than fix the 4cyl trucks, so it isn't hard to get them.
  5. Nov 19, 2017 at 1:49 PM
    rybern
    N Alabama
    Do you know what numbers are on them?
  6. Nov 19, 2017 at 1:53 PM
    Speedytech7
    ゼイン
    Im not near them for a couple days but I know who might know. @MadTaco461
    MadTaco461 likes this.
  7. Nov 19, 2017 at 2:13 PM
    rybern
    N Alabama
    Thanks. I've PM'ed him.
  8. Nov 19, 2017 at 2:20 PM
    BikerinBlak909
    BikerinBlak909 Well-Known Member
    SoCal
    96 LT 5 lug
    JD Fab LT kit 3" lift spindles Fox 2.5 x 10" dual rate Deaver F67 SUA, 9" shackles 8.4 prerunner rear end with 4.10 33 AT3 wildpeaks McNeil Fiberglass fenders PRP comp seats Doug Thorley long tube header K&N CAI
    Check out.http://www.lceperformance.com they have all the oem for tacoma engines and performance but they ain't cheap. The cheapest I was able to find for my 2 rz was rebuilt ones from summitracing
  9. Nov 19, 2017 at 5:38 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    23250-75080
    Are the number on my pinks.
  10. Nov 19, 2017 at 5:54 PM
    rybern
    N Alabama
    It looks like the pink top numbers are 23250-75080 or 23209-75135. Here's two pink top choices from Ebay:
    These are shown sitting on OEM boxes but the injectors themselves look just like some that are from China. https://www.ebay.com/itm/OEM-Fuel-I...ash=item2f0cda9105:g:eek:J0AAOSwLnBX3K58&vxp=mtr
    Ironically, these are pretty cheap but have an OEM part number (23209-75080)on them but are listed as "unbranded".
    https://www.ebay.com/itm/4pcs-OEM-N...ash=item3ad5fd4305:g:izgAAOSwa~BYYhfV&vxp=mtr
    Heck, here's another set of (4) listed as OEM for $60.
    https://www.ebay.com/itm/4pcs-OEM-New-Fuel-Injector-For-Toyota-4Runner-Tacoma-2-7-2-4-L4-23209-79135/291850261695?fits=Year:2000|Make:Toyota|Model:Tacoma&epid=1580885657&hash=item43f3a194bf:g:fPQAAOSwHoFXtrLm&vxp=mtr
    Not really sure which ones are good other than the ones from the online dealer that would cost ~$500 for the set. :eek: I will go ahead and say that I'm not willing to do that. I'll send mine and have them cleaned and flow tested before I spend that kind of money.
    BikerinBlak909 likes this.
  11. Nov 19, 2017 at 5:56 PM
    rybern
    N Alabama
    Thanks.
    MadTaco461[QUOTED] likes this.
  12. Nov 19, 2017 at 6:03 PM
    rybern
    N Alabama
    These have to be the widest range of part I've ever seen on a vehicle.... maybe on anything. I've seen prices ranging from less than $15 each($50 for 4) all the way up to over $200 each. :eek:
  13. Nov 19, 2017 at 6:04 PM
    Speedytech7
    ゼイン
    I'd seriously just get a set from a wreck because then you know they're OEM (low failure rate so people never really have to replace them), then Mr. Injector or Witch Hunter can clean and flow em.
  14. Nov 19, 2017 at 7:09 PM
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
  15. Nov 20, 2017 at 4:25 AM
    rybern
    N Alabama
    Makes sense to me. I wish I had a junk yard nearby. I'll check around.
    That's good to know. Thank for sharing.
  16. Nov 20, 2017 at 4:33 AM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    You could also look at the Osidetiger 330cc injectors as well. They are pretty close in flow rate to the pink tops and should also be PNP as well. They cost a little more than some of the eBay ones at $150+shipping. If you choose these, make sure you get the 330cc saturated so they are higher impedance like your stock ones.
    http://www.osidetiger.com/pages/11mm.aspx
  17. Nov 20, 2017 at 9:41 AM
    cmj
    cmj Well-Known Member
    Oregon
    98 Tacoma 4x4
    The injectors on ebay seem sketchy. 'Genuine' what?
  18. Nov 20, 2017 at 9:43 AM
    Jerry311SD
    Jerry311SD Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
    I'm supercharged I need to find injectors with more flow. My motor starves for fuel if I get into high rpms.
    Looking for maybe N/A Supra injectors. Just something with a little more than stock should help
  19. Nov 20, 2017 at 9:57 AM
    boostedka
    James
    NM
    what size are the stock 5vz injectors?
  20. Nov 20, 2017 at 10:42 AM
    rybern
    N Alabama
    I'm fine with paying $150 for injectors that are good quality. I appreciate the link and suggestion. If folks can vouch for them then I'd consider doing that.
    Seems sketchy to me too.
    I'm leaning toward ordering the ones off Ebay that are sitting on top of the OEM boxes. I'm in communications with the seller trying to verifying OEM.
    There seems to be two different looks to the pink tops. One has "Aisan"(I think its what it says) on them like these:
    The other has a part numbers "23250-75080" or "23209-75135" on them:
