Help choosing injectors please
Discussion in '1st Gen. Tacomas (1995-2004)' started by rybern, Nov 19, 2017.
  1. Nov 21, 2017 at 10:40 AM
    #41
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Yeah it is just one wire. I just cut off the old one and crimped on the new one. I covered it in heat shrink since it's in the motor just to make sure it doesn't come undone.
    Jerry311SD likes this.
  2. Nov 21, 2017 at 11:02 AM
    #42
    rybern
    rybern [OP] Well-Known Member
    N Alabama
    2025 TRD OR & 2000 SR5
    Awesome. Thanks.
    boostedka[QUOTED] likes this.
  3. Nov 21, 2017 at 11:09 AM
    #43
    rybern
    N Alabama
    Hey James, I hate to keep bugging you about this but Autozone would like to know the UPC on the pigtail if you have it. I have the SU1075 ordered and it will be there at 6pm tonight.
  4. Nov 21, 2017 at 11:19 AM
    #44
    boostedka
    James
    NM
    I would have to look at the box at home. IIRC it was for a early 2000's Chevy Cavalier
  5. Nov 21, 2017 at 4:28 PM
    #45
    rybern
    N Alabama
    Bore scope didn't come in today. Tomorrow night is date night with my wife so I won't be able to mess with it until Thursday AM.
    We should be able to figure it out. I didn't make it by Autozone today. I'll pick up the parts tomorrow. I really appreciate your help and suggesting me replace this part.
    boostedka[QUOTED] and Jerry311SD like this.
  6. Nov 22, 2017 at 7:26 AM
    #46
    boostedka
    James
    NM
    I got my Manifold reinstalled last night:
    Here you can see the knock sensor installed:
  7. Nov 22, 2017 at 7:46 AM
    #47
    rybern
    N Alabama
    Looks great James. Did you fire it up? Also, did you delete the coolant through the TB? If so, I'm assuming research led you to benefits, right?
  8. Nov 22, 2017 at 9:54 AM
    #48
    BikerinBlak909
    BikerinBlak909 Well-Known Member
    SoCal
    96 LT 5 lug
    JD Fab LT kit 3" lift spindles Fox 2.5 x 10" dual rate Deaver F67 SUA, 9" shackles 8.4 prerunner rear end with 4.10 33 AT3 wildpeaks McNeil Fiberglass fenders PRP comp seats Doug Thorley long tube header K&N CAI
    Do any of you know if these injectors will a 96 2rz? I don't think they are the same for all years.
  9. Nov 22, 2017 at 10:17 AM
    #49
    boostedka
    James
    NM
    I didn’t start it up yet. I need to find a plug to replace the EGR sensor since I deleted everything else EGR. I also added an extra vac port on the back of the manifold so I need to get a bit of line to hook all that up.
    I deleted the TB coolant lines when I turbo’d since some guys said it actually raised the Intake temps after being intercooled
  10. Nov 22, 2017 at 10:49 AM
    #50
    boostedka
    James
    NM
    I think that @mjbtaco ran pinks on his 2rz. IIRC his truck is a 96 or 97
  11. Nov 23, 2017 at 8:36 AM
    #51
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    That is correct any 95-04 2rz injectors should drop right in to any year. I did run pink tops in my 95.
