Help clearing codes
Discussion in '1st Gen. Tacomas (1995-2004)' started by NOLA ItsNotOva, May 26, 2014.
  1. May 27, 2014 at 9:36 AM
    MrRiverMan
    MrRiverMan Compulsive tinkerer
    WNC
    2002 Taco 2.7 4x4 auto, 96 Taco 2.7 4x4 manual, previously 2003 Taco 4x4 auto, 2000 Taco 2.7 4x4 manual, 1994 22RE 4x4 manual, and 1996 T100 4x4 auto
    http://www.tacomaworld.com/forum/1st-gen-tacomas/194366-how-replace-o2-sensors.html
    It shouldn't be too hard. You might want to check the connection before you replace the sensor - it could be the connection, wiring, or sensor itself.
    Judging by your lean error codes, I suspect your sensor has been slowly dropping in performance over time as it wore out until it finally threw the P0135.
    I think the ECU uses the air flow reading from the MAF combined with the readings from the upstream O2 sensor to determine how to adjust the fuel/air mix for best running of the vehicle. So having one of those sensors go bad is very often the cause of lean mix errors like the ones you started this problem with.
  2. May 27, 2014 at 9:49 AM
    NOLA ItsNotOva
    NOLA ItsNotOva [OP] Well-Known Member
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    So what would I look for if I'm just testing the connector?
  3. May 27, 2014 at 9:56 AM
    MrRiverMan
    WNC
    Obvious breaks or wear in the wires?
    If you google, there are also tests you can do with a multi-meter to determine if the O2 sensor is actually bad before you replace it.
    I also recommend that you double the number of cold beverages prescribed in that tutorial since you're working in NOLA. Make one of them a huge daquiri for me. Yeah you right-
  4. May 27, 2014 at 2:25 PM
    Andyd103
    Andyd103 Well-Known Member
    Andrew
    New Hampshire
    2002 Tacoma SR5 4WD (3.4L V6)
    Suspension Lift, 40mm Turbo
    Check for exhaust leaks first, check the upstream sensor (very accessible from underneath) if you have a multi-meter check the sensors resistance i think it should be between 10-16 ohms to function correctly. Sometimes cleaning the sensor off will help.
  5. May 27, 2014 at 3:05 PM
    MrRiverMan
    WNC
    I would agree with checking for exhaust leaks if this was to address a P0420 - but I don't think an exhaust leak can cause a P1135.
    Checking the sensor's resistance is definitely a good idea.
    However, I suspect that because this is the sensor heater circuit that is bad, he will end up replacing that O2 sensor.
    Make sure you buy an OEM Denso sensor to replace it with. Rockauto is usually a good place to find the OEM stuff cheap. I think it's only a matter of unplugging the sensor and removing two 10mm nuts to swap it out.
  6. May 27, 2014 at 3:11 PM
    Andyd103
    Andrew
    New Hampshire
    yeah it's two highly rusted 10mm bolts and a standard toyota connector. Make sure if your going to pull this sensor that you start saturating the bolts a day or two before so you don't mar the nuts or break the bolts off.
  7. May 27, 2014 at 3:20 PM
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    ...or an air fuel ratio sensor that is stuck at .66v like was the case for me. Cured my P0171.
  8. May 27, 2014 at 5:10 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    Do you know what the readings for the AF sensor and downstream O2 sensor should be?
    I'm curious because I just replaced the upstream and downstream sensors and I'm watching them on my Ultra guage. I see the upstream usually stays around 1.00v and the downstream is kind all over the place between .400v-.800v.
    Just wondering if these are normal outputs for a system that is running properly.
  9. May 27, 2014 at 5:22 PM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Here's my o2 sensor. Doesn't appear to have anything messed up with wiring anything like that
  10. May 27, 2014 at 5:24 PM
    Andyd103
    Andrew
    New Hampshire
    Unclip it and check it's resistance, only way to know for sure. Takes literally 15 seconds.
  11. May 27, 2014 at 5:25 PM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Where do I grab?
  12. May 27, 2014 at 5:31 PM
    Andyd103
    Andrew
    New Hampshire
  13. May 27, 2014 at 5:34 PM
    Andyd103
    Andrew
    New Hampshire
    I should mention, all the clips are the same but you need to wedge a flat head in the hole where you think you would press and pull it out of the retaining clip.
