NOW FIXED! Coil Compressor Hooks Stuck
Discussion in '3rd Gen. Tacomas (2016-2023)' started by El Taco Blanco, Jan 23, 2020.
  1. Jan 23, 2020 at 6:07 PM
    El Taco Blanco
    El Taco Blanco [OP] Well-Known Member
    2017 White Tacoma SR5 4x4 DCLB
    Stock (for now)
    I’m installing my dobinson coils on some 5100’s. I’m on the bottom perch. Everything looks perfect, just can’t get the dang compressor hooks out. Anyone have a suggestion? Thanks.
  2. Jan 23, 2020 at 6:37 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    I'm not an expert in this matter, but it looks like you have too much preload for that style of spring compressor. Need to remove the coils, take the compressor off and then source a different style compressor with smaller hooks. Or take it to a shop to install them on a press.
  3. Jan 23, 2020 at 6:47 PM
    Da Boogie Man
    Da Boogie Man Purple Nurple
    Seymour
    They will fall out eventually.
  4. Jan 23, 2020 at 6:57 PM
    Ducman82
    Ducman82 Well-Known Member
    jake
    2016 Sand Tacoma TRD
  5. Jan 23, 2020 at 7:00 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Hammer them out in this direction just like I illustrated.
    El Taco Blanco[OP] and whatstcp like this.
  6. Jan 23, 2020 at 7:02 PM
    Superdave1.0
    SoCal
    I have the same exact spring compressors. Don't listen to this ^
  7. Jan 23, 2020 at 7:03 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Gently drive a wood wedge in.
    whatstcp and Superdave1.0 like this.
  8. Jan 23, 2020 at 7:06 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    whatstcp, FishnTx and Superdave1.0 like this.
  9. Jan 23, 2020 at 7:13 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    If the first line of that statement didn't tip you off... then let me help you. It was a suggestion of a fix. Maybe not THE fix, but a solution none the less.
  10. Jan 23, 2020 at 7:13 PM
    El Taco Blanco
    Stock (for now)
    Before I started getting too medieval with it, I put the compressor bolt back in and rotated them out using leverage. I had to pull pretty hard. I seems like this particular compressor has extra long and thick jaws on the hooks. I got them out finally. Thanks for the suggestions. I wasn’t worried about too much pre load as they are only a 1.5” coil and I’m on the lowest perch. The compressors were just too dang thick.
  11. Jan 23, 2020 at 7:13 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    As mentioned, drive a wedge in to open up between the coils and remove the tool. Wood or plastic would be best to hopefully not damage the finish.
    Cudgel and whatstcp like this.
  12. Jan 23, 2020 at 7:15 PM
    Superdave1.0
    SoCal
    You don't know the answer, but you are the first to respond??? Your first line said "I'm not an expert." Could have let the people that know what they are doing respond before giving poor advice.
  13. Jan 23, 2020 at 7:16 PM
    El Taco Blanco
    Stock (for now)
    Although I wouldn’t have done this. This stuff definitely does cross your mind when this happens. :rofl:
    Ducman82[QUOTED] likes this.
  14. Jan 23, 2020 at 7:18 PM
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    Cool...be sure to edit your title.
  15. Jan 23, 2020 at 7:19 PM
    Superdave1.0
    SoCal
    That is the best way. Sliding the end of the bolt in and using the long bolt as leverage to pry it out. Good shit!
    :cheers:
  16. Jan 23, 2020 at 7:22 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Are you saying that my method wouldn't work?
    My spring compressors have smaller hooks and don't require "beating them" with a hammer.
    Sorry that you don't like my method, but that doesn't make it a poor method.
    Shellshock, FishnTx and Crikeymike like this.
  17. Jan 23, 2020 at 7:26 PM
    El Taco Blanco
    Stock (for now)
    Those would have worked so much better than the ones that I used.
    Bertw192[QUOTED] likes this.
  18. Jan 23, 2020 at 7:27 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
  19. Jan 23, 2020 at 7:31 PM
    Crikeymike
    Crikeymike ExitOffroad.com Vendor
    Jax Beach, Florida
    You're definitely not the first to have that issue. Glad you got it sorted out.
    The best thing to use is a proper strut spring compressor, one that doesn't have jaws/teeth as thick as those. The other guy's kit looks pretty cool, I haven't seen that "thinner" type around much.
  20. Jan 23, 2020 at 7:31 PM
    El Taco Blanco
    Stock (for now)
    I’m all of the way in Georgia, but that is a pretty cool service that you have going on up there. :thumbsup:
