Help! Coolant doesn’t get into engine block during flush
Discussion in '4 Cylinder' started by tacolover619, Jan 21, 2019.
  1. Jan 21, 2019 at 9:05 PM
    tacolover619
    tacolover619 [OP] New Member
    Started a flush on my 2004 prerunner 2.7L by draining the radiator but when I opened the engine block coolant drain plug nothing came out. I had just swapped an Engine Coolant Temp sensor and figured it must’ve drained when I removed it.
    However, I started filling it up with distilled water and only got about 1.25 gallons before it was full. Water came out Radiator drain but still not coming out of the engine block drain. Removed thermostat and tried it again but still nothing coming out of engine block.
    Any ideas what is preventing fluid to enter engine block? Could it be some air trap when I removed the engine coolant temp sensor?
    Any help appreciated!
  2. Jan 21, 2019 at 9:11 PM
    TacosConQueso
    TacosConQueso Well-Known Member
    Brian
    1999 Sierra Beige Tacoma 4x4
    Welcome!
    I have yet to do this job myself, but how are you adding the water? I think it has been recommend to disconnect the upper hose and add through it to fill the block.
    Maybe someone more experienced can chime in
  3. Jan 21, 2019 at 9:20 PM
    tacolover619
  4. Jan 22, 2019 at 10:30 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    You might try removing the plug completely from the end of the drain fitting on the side of the block. If you still don't get any outflow, I would poke around in there (gently) with a long screwdriver.
    Good luck.
  5. Jan 22, 2019 at 2:24 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    did you run the engine up to operating temp after refilling with water
  6. Jan 22, 2019 at 6:07 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    Might be rust or crud in the plug depending on how maintenance was kept up with on the truck. Or could have an air bubble or ai lock. When you have the eninge drain open is the radiator cap also off.
    Maybe somebody put stop leak in it before. I've replaced freeze plugs in engines before that had stop leak added and they had a ton of sludge and stuff in the water jacket
  7. Jan 23, 2019 at 9:01 PM
    tacolover619
    Hey everyone, thanks a lot for the help. You guys were right and it was just a bunch of rust build up since the truck hand´t been maintained very well.
    Took DGXR advise and poked at it with a thin sharp metal file and its finally draining!
    tcjacado likes this.
  8. Jan 24, 2019 at 7:34 AM
    BillsSR5
    bill
    2014 SR5
    glad you got it worked out, hardest part is getting to that petcock in order to open it
