Help! CV joining with wheel hub broke camping
Discussion in 'Canada' started by Yukon DoIt, May 22, 2021.
  1. May 22, 2021 at 7:49 PM
    Yukon DoIt
    Yukon DoIt [OP] Opinionated Northerner
    Paul
    Yukon, Canada
    2006 White Tacoma DCLB 4wd Auto, 1988 Blue 4Runner 4wd Manual
    Stock-y
    Hey guys,
    I need help. My truck busted and I'm in the middle of nowhere with barely any service. Something has broken where the CV axle turns the wheel on my front driver side. Right now the axle is almost completely free of the wheel hub, and I can push it in and almost pull it out of the wheel hub while I'm turned all the way to the left, but not quite. There seems to be some cogs on the end of the axle that I can see when I push it in towards the differential, and there was some part that seemed to fit over those cogs that's snapped in two, like a bearing race with holes in it to accept the cogs. Right now the differential end boot is holding everything together. Is it okay to drive like this? Right now it knocks when the wheel is turning in that axle. Should I try to remove it all the way? I need to know if I can get home.
    I'm sure the answer is on the forum's but I can't search well with my limited service.
  2. May 22, 2021 at 7:59 PM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Remove the cv from diff but leave the outer section in hub if you can. It needs to be in there for the truck to drive.
    TnShooter likes this.
  3. May 22, 2021 at 8:01 PM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    Bump let’s save this mannnn
    Yukon DoIt[OP] likes this.
  4. May 22, 2021 at 8:03 PM
    tcjacado
    tcjacado Well-Known Member
    This would be the 2nd one of these today.
    TnShooter, Mully, wilcam47 and 2 others like this.
  5. May 22, 2021 at 8:06 PM
    Yukon DoIt
    Paul
    Yukon, Canada
    Stock-y
    The hub part is the part that's effed though. Hub being where the wheel is anyway. I can push the axle almost all the way out of the hub and it is seemingly separated from it. The truck drives though, because it's still got rear wheel drive. Know what I mean? There is like a castle head on the end of it I can see when I try to yank it out of the hub, there's just barely not enough clearance to get it out. I need to know if this means my wheel can come off with the bearing or not...
  6. May 22, 2021 at 8:08 PM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Moved to Canadian section.
    How close are you to Alaska?
    Closest city?
    wilcam47 and tcjacado like this.
  7. May 22, 2021 at 8:09 PM
    tcjacado
    I'll post the thread that happened today.
    https://www.tacomaworld.com/threads/passenger-side-half-shaft-broke.722269/#post-25719641
    hoffengineering likes this.
  8. May 22, 2021 at 8:09 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    The axle nut could have come loose somehow. You might be able to fix it a put it back on. It’s hard to say without being there
  9. May 22, 2021 at 8:10 PM
    Yukon DoIt
    Paul
    Yukon, Canada
    Stock-y
    This move isn't going to help me, I need all the exposure I can get... Why would I get moved if my post wasn't regional :confused:
    Anyway, yea the Yukon is right next to Alaska. I'm not really close in the scheme of things right now.
  10. May 22, 2021 at 8:11 PM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
  11. May 22, 2021 at 8:12 PM
    Yukon DoIt
    Paul
    Yukon, Canada
    Stock-y
    Ok, so let's say we can't put it back on, as I'm fairly sure that's not an option at this point?
  12. May 22, 2021 at 8:13 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Can you take a pic? It could be a option if threads aren’t messed up.
  13. May 22, 2021 at 8:15 PM
    Yukon DoIt
    Paul
    Yukon, Canada
    Stock-y
    I wish I could. The connection can barely get my posts out. All I can say is something is effed where the CV axle goes into the hub, it looks like what the axle uses to drive the wheel. If the axle is free of the hub, does that mean my wheel can come off if nothing is done?
  14. May 22, 2021 at 8:16 PM
    Yukon DoIt
    Paul
    Yukon, Canada
    Stock-y
    I'm thinking the threads are gone because I did drive a little ways with it clicking and clunking.
  15. May 22, 2021 at 8:18 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Take the wheel off, pull the dust shield off and verify the axle nut and outer cup are still intact.
  16. May 22, 2021 at 8:20 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Wheel can’t come off since it’s bolted to hub that’s bolted to spindle. Make sure the axle nut still connected. Not sure if you carry around a 35mm cause that’s what it calls for. As long as it’s tight you should be able to get where you going in 2wd unless your in some thick stuff or snow/ice which is a part of the country your in.
    Taco-Obsessed likes this.
  17. May 22, 2021 at 8:21 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Sounds like front bearing failed.
  18. May 22, 2021 at 8:26 PM
    ColoradoTJ
    Colorado
    I moved the thread to see if someone was close to help you out.
    tcjacado and theesotericone like this.
  19. May 22, 2021 at 8:29 PM
    Taco-Obsessed
  20. May 22, 2021 at 8:41 PM
    Yukon DoIt
    Paul
    Yukon, Canada
    Stock-y
    I'm trying to post a picture but it just won't go :(. I need someone to show me what they mean by axle nut and outer shell. I'm leaning that I'm SOL right now since it seems to me that the axle is not connected to the wheel assembly at all.
