Help diagnosing problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by rob1208lv, May 23, 2011.
  1. May 23, 2011 at 8:41 AM
    rob1208lv
    rob1208lv [OP] Well-Known Member
    Rob
    Las Vegas
    02 PreRunner V6
    Ok My 2002 v6 pre-runner has a issue but I'm not sure what it is. I want to know whats going on before i take it in just in case the mechanic tries to rip me off
    History- I got the truck from my mom (deceased) and since I took it over it had this problem, unknown how long its had the issue
    Problem 1 - when driving and not accelerating the is a high pitched noise
    Problem 2 - when I come to a stop the truck jolts. I thought it could be a axle seal, but no sign of grease on any axle, So I thought maybe a motor mount but the ones I can see seem ok. is it a transmission thing?
    Thanks in advance
  2. May 23, 2011 at 9:00 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    For your first problem, check the simple stuff. I'd start with making sure you have life left in the brake pads. How loud of a noise is it? Also, not sure if this applies to first gens, but grease the driveline if you can.
    The second, try taking the transmission out of the equation, put it in neutral and come to a stop the way you normally would and see if it still jolts. The results of this should at least help narrow the search.
  3. May 23, 2011 at 9:29 AM
    ERIC
    ERIC Well-Known Member
    Eric
    Orange County, CA
    2002 Impulse Red TRD PreRunner SOLD
    Pioneer double din navi head unit and four 5x7 alpine speakers, westin light bar, procomp lights, head and tail lights, black billet grille, billet antienna, gibson headers and cat back exhaust, afe cold air, uni chip programmer, Bilstein 5100's, Pro comp wheels and tires, tint, blacked out emblems, innu roof rack, yakima basket, foglight mod...
    not sure about problem #2 but could be a solenoid problem in the trans. Problem number #1 could be a bad wheel bearing or try greasing the drive shaft joints.
  4. May 23, 2011 at 10:24 AM
    rob1208lv
    Rob
    Las Vegas
    02 PreRunner V6
    That's a good idea I'll try that (idle). I'll also grease all the drive train.
    Thanks
  5. May 24, 2011 at 5:29 AM
    rob1208lv
    Rob
    Las Vegas
    02 PreRunner V6
    UPDATE - I tried the stopping in neutral and the jolt thing didn't happen. Does this mean something with the tranny? I also Greased the drivetrain, changed the oil/filter, changed the a/c.alternator, and power steering belts, and spark plugs.
  6. May 24, 2011 at 6:03 AM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    problem 1 sounds like a front wheel bearing like Eric said, how many miles on the truck? Question on the second problem, is it like a clunking sound when you stop? I have a 1st gen taco and you have to grease the drive shaft good and purge the universal joints once in a while or you will hear that clunking when you stop.
  7. May 24, 2011 at 6:12 AM
    rob1208lv
    Rob
    Las Vegas
    02 PreRunner V6
    I greased the drivetrain but I'll check the again today and try to purge, dont really hear a noise though.
  8. May 25, 2011 at 6:33 AM
    rob1208lv
    Rob
    Las Vegas
    02 PreRunner V6
    I'm taking it in tomorrow, I'll update on what they say it is..
  9. May 25, 2011 at 9:45 AM
    HeadlampRevamp
    HeadlampRevamp Well-Known Member
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    Ditto, def sounds like wrap
  10. May 25, 2011 at 10:13 AM
    rob1208lv
    Rob
    Las Vegas
    02 PreRunner V6
    The auto shop teacher at a local high school seems to think its the tranny and he said my tranny fluid is dirty to have it flushed. But I'm not sure how great of a mechanic he is
  11. May 25, 2011 at 10:20 AM
    scocar
    scocar hypotenoper
    If you don't have maint. records for the truck, it is cheap insurance to swap out all the fluids. If the tranny fluid isn't a nice, bright red, have it flushed. This is the fraction of the cost for a new transmission, no?
  12. May 25, 2011 at 10:28 AM
    Pugga
    Massachusetts
    How many miles on on the transmission and do you know the history of it (was it used to tow/haul or more of a commuter). I have my doubts whether a transmission fluid flush will solve your problem, I'd be more apt to think it's a solenoid as mentioned above. How does it drive, does it feel like the torque convertor slips or does your shop teacher say anything else to back up his claim, like how he diagnosed it? Who knows, he might be correct and as stated above, a fluid flush is cheaper than rooting through the transmission for problems.
    One thing to keep in mind with really high mileage or hard worked vehicles, changing the transmission fluid can sometimes cause more harm than good. Sounds counter intuitive but the grit in the fluid actually becomes what the torque convertor relys on to function. Remove the grit, the fluid is thin again instead of gritty, and it starts slipping like crazy. Please do not take this out of context, I am not telling you not to change your transmission fluid or saying old, worn out fluid is better than a clean flush, just something to be cautious of.
  13. May 25, 2011 at 10:29 AM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
  14. May 25, 2011 at 11:33 AM
    rob1208lv
    Rob
    Las Vegas
    02 PreRunner V6
  15. May 25, 2011 at 11:35 AM
    rob1208lv
    Rob
    Las Vegas
    02 PreRunner V6
    Has 94k miles no history of maintenance, I work for the school and he is not my teacher (I'm 33 years old). He just said the tranny fluid looked a little dirty. I asked him does that mean my tranny is going out? he said no. So I plan on flushing the tranny and doing the axle wrap mod.
  16. May 25, 2011 at 12:04 PM
    Pugga
    Massachusetts
    Didn't check your age, just figured you were in a trade school or something :eek: Sounds like a transmission flush couldn't hurt!
  17. May 25, 2011 at 12:23 PM
    rob1208lv
    Rob
    Las Vegas
    02 PreRunner V6
    No worries, Thanks for your help,
    is this http://www.amazon.com/Superior-11-10...6348282&sr=1-2
    the kit i need for axle wrap
  18. May 25, 2011 at 6:05 PM
    JAJI4
    JAJI4 Well-Known Member
    Sunshine State
    2001 Tacoma; Double Cab; TRD Offroad; 2WD
  19. May 26, 2011 at 10:37 PM
    rob1208lv
    Rob
    Las Vegas
    02 PreRunner V6
    Don't have those in Vegas I went ahead and ordered the
    One from Amazon. Thanks for your help
  20. May 26, 2011 at 11:48 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Your clunkity clunk when stopping or taking off from a stop is probably going to be axle wrap (about 99% sure on this) The squeeling could be a few things Any audio you can post up ??
