HELP - front rotor removal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gavonder, Oct 2, 2010.
  1. Jul 9, 2013 at 10:39 AM
    jonsey4411
    jonsey4411 New Member
    James
    Kingsport, TN
    07 Black TRD Sport
    Grill, Electric Supercharger, KC lights
    Awesome post shipmate! Thanks.
  2. Jul 9, 2013 at 11:12 AM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    Cut the rotors off w a cutting wheel. Be careful. Whacking them too hard not only subjects the wheel bearings to beating but I don't think you alignment ect will like it either.
  3. Jul 9, 2013 at 3:22 PM
    rleete
    rleete Grumpy old man - get off my lawn
    Roger
    Rochester, NY
    Base DC, SR5, TRD Sport
    Billet grill
    To break rotors free, hit the rim straight towards the center. Like you're trying to shear off the studs. Don't worry, you won't. Just don't miss and hit the studs, or you'll mess up the threads. Several good whacks will break the most rusted rotor off.
    Nev-r-seez is your friend. Buy a can and use it. Behind rotors, all threads. Note that it is NOT grease, so don't use it on slider pins and such.
    One small can will last for decades. I've had the same one since I moved in here, (which was 1986) and it's still over half full. I do all my own brakes, so it's serviced a lot of cars over the years.
  4. Jul 9, 2013 at 3:43 PM
    Seer
    Seer Well-Known Member
    Tom
    Bayfield, CO
    13 Double Cab 4x4 stock
    Is it really taking this dude 2 1/2 years to get his rotors off?
    wilcam47 and Alexely999 like this.
  5. Jul 9, 2013 at 3:48 PM
    B737
    Kevin
    Jersey Shore
    stock
    yes
    Alexely999 likes this.
  6. Jul 9, 2013 at 4:40 PM
    Seer
    Tom
    Bayfield, CO
    :rimshot:Haha! Taco becomes lawn ornament!
  7. Sep 17, 2014 at 4:01 PM
    wormfood
    wormfood Well-Known Member
    David
    Missouri
    2011 Tacoma TRD
    TRD Super Charger, UWS, All Pro expedition leaf spring pac, Icon stage 4 suspension, B.A.M.F LCA Skid plates, TC weld-on upper coil bucket tower gussets, TC weld-on spindle gussets with sway bar mounts. RTT, Thule Roof Rack, Thule, Leitner Active Cargo System, Warn Zeon 10 Winch, All Pro Front Bumper, All Pro Apex Sliders, Nilight - 60005C-A 20Inch 126W Spot Flood Combo Led Light Bar.
    I wouldn't have revived this but it is the one that schooled me and got the job done.
    Doing a pad/rotor upgrade to my 2011, and painting the calipers. I removed a bolt holding the stock air filter to the wheel well from inside the engine bay. Used it to insert through the provided holes on the stock rotors, and they came right off. Put the 12mm bolt back.
    Having a busted left hand atm, this came in real handy.
    Biscuits likes this.
  8. Oct 1, 2015 at 2:55 PM
    T in NL
    T in NL New Member
    Trevor
    Newfoundland, Canada
    2005 TRD off-road
    Erik - if you happen to read this I just wanted to send my thanks - the bolt made it easy. The caliper bolts were another story - heat and penetrating oil along with a healthy dose of elbow grease!
    Cheers!
  9. Aug 28, 2018 at 11:56 AM
    Brownfp
    Brownfp New Member
    Frank
    2002 Tacoma TRD
    Found this thread helpful, thx! I have the rotors without the two screw holes, but I found a workaround: I screwed one of the caliper screws back in its hole (without the caliper). It's long enough to come in contact with the back of the rotor. I put a wooden shim between the screw and rotor so as not to mar up the end of the screw. Worked like a champ!
  10. Aug 28, 2018 at 4:45 PM
    wormfood
    David
    Missouri
    2011 Tacoma TRD
    It is cool to see info from a few years back still helping out.
  11. May 13, 2020 at 5:40 PM
    HolyReptar
    HolyReptar Well-Known Member
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    Some Bolt ones here and there
    You’re a f**king life saver
    PreRunnerSeth[QUOTED] likes this.
  12. May 13, 2020 at 6:47 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    Wow that post was from 2011. Glad it's still useful.
    HolyReptar[QUOTED] likes this.
  13. May 13, 2020 at 7:26 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Where did you ever see a set screw holding a rotor?
    I have never seen a rotor affixed to a hub with anything except the caliper and the lug nuts/wheel holding it all together.
    Crap, I was caught by a Zombie. :(
  14. May 13, 2020 at 9:08 PM
    pinktaco808
    pinktaco808 Hot Steppa
    What about drums
  15. May 13, 2020 at 10:30 PM
    #35
    6 gearT444E
    Deep South
    Herculiner Hootus
    Honda’s have two from the factory. They take a p3 JIS screwdriver.
    ericvega, Jimmyh[QUOTED] and wilcam47 like this.
  16. May 13, 2020 at 11:46 PM
    #36
    Jimmyh
    SC
    2012 Prerunner SR5
    Thanks for the info. I've never worked on a Honda (Thank God!)
    Had to look it up. I don't see the point and who has JIS Screwdrivers for a brake job... Geez.
  17. May 14, 2020 at 4:36 AM
    #37
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    Really? It’s very common
  18. May 14, 2020 at 4:46 AM
    #38
    6 gearT444E
    Deep South
    Herculiner Hootus
    a Phillips will get you out in a pinch, but usually they are seized in there good so they will strip. I had to buy an impact JIS screwdriver, it made my life a bit easier.
    wilcam47 and Jimmyh[QUOTED] like this.
  19. May 14, 2020 at 8:22 AM
    #39
    pinktaco808
  20. May 14, 2020 at 8:32 AM
    #40
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    old thread I know but your post is new...to avoid having to get the JIS screwdriver, when those screws are seized, take your regular Phillips head screwdriver and insert it into the screw head, then take a hammer and give it a couple good whacks on the end and it will break the screw treads free and they will unscrew with the Phillips head with ease...
