Help! How do I remove the ceiling console?
Discussion in 'Technical Chat' started by MUDDA, Nov 6, 2007.
  1. Nov 6, 2007 at 7:42 AM
    MUDDA
    MUDDA [OP] Member
    Utah
    Black TRD SPORT
    Pro-Comp 6" Lift, Moto-Metal 950 18" Rims, Toyo Open Country 33 12.50 18 Tires, Flowmaster 50 Series, K&N intake, Seccondary filter removal, Navigator 12V 55W Driving Lights, 700W Power Inverter installed Beneath Driver Seat
    I am one of those freaks who hates seeing wires all over my dash from accessories that are suctioned to my windshield, or any aftermarket wires at all for that matter. I even went to the trouble of routing my cell phone power cable to the center console to minimize wires in my cockpit. (BTW it is wonderful)
    THE POINT: I want to wire my radar detector up into the ceiling console and clean up the dash.
    THE PROBLEM: I can't get the dang thing off the ceiling! There is a screw in the sunglasses compartment, but removing it proved no help.
    THE PETITION: Anyone who knows how to get it off? Please let me know how the flip to do it.
  2. Nov 6, 2007 at 8:20 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    PM user "pb2themax", he'd done it before when installing his Scangauge up there. I'm too lazy to look for the thread over on TN now.
  3. Nov 6, 2007 at 8:48 AM
    sawdust
    sawdust Unapologetic Texan
    Frisco, TX
    07 TRD Offroad Radiant Red V6 Auto DC
    Homelink mirror, tailgate lock, 2ndary air filter removal, Access LE tonneau, Bugflector II, hitch-based bed extender, vent visors, suspension TSB, stall mat
    If I recall correctly, from pb2themax's postings, after unscrewing the single screw in the sunglass holder, you pull the side near the windshield down and pop off some clips.
  4. Nov 6, 2007 at 3:05 PM
    bao523
    bao523 Active Member
    houston, tx
    08 trd offroad double cab
    weather tech window visors, skid plate, roll bak bed cover, step bars, 18" rims
    if you grab the console towards the front and pull it will come off. there are two clips, one on each side of the console. they will snap off and the console will come out. i had problems too when i wired my radar.
  5. Nov 6, 2007 at 9:13 PM
    MUDDA
    MUDDA [OP] Member
    Utah
    Black TRD SPORT
    ROCK ON! Thanks Guys. It worked like a charm. It is clipped up there pretty tight and so I figured that it was attached to the carpet, but it poped right out. I gotta admit that it took a lot of guts to yank down on it that hard (OK, it was my friend, but still)
    For anyone else trying to do the same, the GREEN WIRE plugged into the compass is the one you want to splice into. it turns on with the key so it's not on all the time, only when it needs to be. My dash looks tons better now.
  6. Mar 29, 2011 at 6:55 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
  7. Mar 31, 2011 at 2:58 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    I replaced my map lights a while ago. If I remember correctly, I removed the clear plastic lens (that you push on to turn on the light). Then I used a jewelers screwdriver to push the bulb out of the socket from the back.
