HELP! How do I remove the FRONT Center Console?
Discussion in 'Technical Chat' started by MUDDA, Feb 12, 2008.
  1. Feb 12, 2008 at 9:58 AM
    MUDDA
    MUDDA [OP] Member
    Utah
    Black TRD SPORT
    Pro-Comp 6" Lift, Moto-Metal 950 18" Rims, Toyo Open Country 33 12.50 18 Tires, Flowmaster 50 Series, K&N intake, Seccondary filter removal, Navigator 12V 55W Driving Lights, 700W Power Inverter installed Beneath Driver Seat
    :mad: Alright, So I am attempting to Put the 115V Outlet just past my cup holders and can't get the dumb piece out. I have the cup holders out but the piece that the cup holders clip into will not come out. HELP
  2. Feb 12, 2008 at 3:53 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I just went through all that about a month ago... I have an Automatic just FYI
    In order to get that out - you'll have to remove the center console completely. It's all clipped together and you can't get any movement outta it unless the console is removed.
    At the bottom of the console, you have to pry that fuzzy felt hard thing out and underneath there are 2 bolts holding console in.
    And, if you don't already have the shifter components out....on the Automatic, there are 4 screws holding that piece in at the shifter.
  3. Feb 21, 2008 at 10:27 PM
    MUDDA
    MUDDA [OP] Member
    Utah
    Black TRD SPORT
    thanks, man. Your trick worked like a charm.
