Help identifying leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hudhawk, Feb 14, 2012.
  1. Feb 15, 2012 at 5:26 PM
    hudhawk
    hudhawk [OP] #texasforever
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    Thanks man, do you mind sharing how much the dealership charged to fix everything?
  2. Feb 15, 2012 at 5:33 PM
    bigmooze
    bigmooze Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    The fix was covered by warranty. Good for me, but not very helpful for you, sorry. There was no mention of the w/o about time spent to fix it either.
    I would think that if you could get to the pulley (behind the radiator/fan), the fix would be simple: remove serpentine belt, remove crankshaft pulley, pull out old seal, replace seal and re-assemble. Easy in principle I guess, but things might not be so in practice.
  3. Feb 14, 2015 at 4:37 AM
    Gabassman
    Gabassman Drive it like a 4WD
    Tyler
    Georgia
    Well what was the diagnosis of this leak and the fix?
  4. Feb 14, 2015 at 5:19 AM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    I just changed this seal last summer. Do yourself a favor and remove the radiator shrouds. It only takes a few minutes and it gives alot more working room. And cover the back of the radiator with cardboard so you don't ding it up. The pulley bolt was a major pain in the ass.
  5. Feb 14, 2015 at 5:24 AM
    Gabassman
    Tyler
    Georgia
    Which seal did you replace exactly? The one on the pan that goes around the bottom of the engine of the seal on the crank shaft?
  6. Feb 14, 2015 at 5:29 AM
    Old School
    Old School You are ignoring covfefe by this member.
    Just a thought, take it to the dealer, ask them to check tsb's and recalls
    And ask them for a estimate/diagnosis of oil leak
    You don't have to have them fix it, and they might find some tsb's that need to be checked;)
  7. Feb 14, 2015 at 5:29 AM
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    Mine was leaking from the crankshaft front seal. I need to replace the seal and the pulley or it will start to leak again. My mechanic don't know that, cause it was the first tacoma he had done. Pulley, seal and labor was about $360.00, took him a hour from the time I got there to the time I left.
  8. Feb 14, 2015 at 5:30 AM
    Gabassman
    Tyler
    Georgia
    Well tsbs are great when you are under warranty. This leak didn't start till after 150000
  9. Feb 14, 2015 at 5:32 AM
    Old School
    tsb's and recalls continue after warranty
  10. Feb 14, 2015 at 5:33 AM
    POOLGUY
    JEFF
    ALABAMA
    I had around 174000 miles
  11. Feb 14, 2015 at 5:48 AM
    Gabassman
    Tyler
    Georgia
    Recalls do but not tsbs
  12. Feb 16, 2015 at 9:32 AM
    Gabassman
    Tyler
    Georgia
    Why do you replace the pulley
  13. Feb 16, 2015 at 9:42 AM
    bigmooze
    Richard
    Belle River, ON
    Dealership said the original one was a poor fit. Don't know how true that is, I didn't ask any questions because the fix was covered by warranty for me. Have a look at my post about and look up the cost of the new pulley. Since you have to take it off to get to the seal, you may as well install a new one if the price is right.
  14. Feb 16, 2015 at 9:47 AM
    POOLGUY
    JEFF
    ALABAMA
    Because it gets little groves in it, and the new seal doesn't seat to it good. It starts to leak again. The fist seal was good but started leaking, so we replaced the pulley and seal no problems. My understanding fords and Chevys have a sleeve that you put on the pulley, but tacomas don't.
  15. Feb 16, 2015 at 9:47 AM
    #35
    Old School
    Sometimes the higher mileage, old seals can wear a groove in the pulley
    At which point it goes under tolerance, time to replace, or fit a sleeve
  16. Feb 16, 2015 at 9:48 AM
    #36
    bigmooze
    Richard
    Belle River, ON
    ^ good to know, thanks
  17. Feb 16, 2015 at 9:49 AM
    #37
    Old School
    Damn, beat me by a millisecond!:D
  18. Feb 16, 2015 at 10:13 AM
    #38
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Never mind crank pulley make sure you install it with new crank bolt :D
    And Tighten to spec
  19. Feb 16, 2015 at 3:36 PM
    #39
    Gabassman
    Tyler
    Georgia
    So I assume the pulley and shaft is one piece and to replace the shaft you must replace the pulley?
  20. Feb 16, 2015 at 4:20 PM
    #40
    POOLGUY
    JEFF
    ALABAMA
    yes the pulley and shaft are one piece.
