Help identifying leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hudhawk, Feb 14, 2012.
  1. Feb 16, 2015 at 4:24 PM
    #41
    Gabassman
    Gabassman Drive it like a 4WD
    Tyler
    Georgia
    I see I looked them up. They are fairly pricy.
  2. Feb 16, 2015 at 4:32 PM
    #42
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    how much? got the pulley and seal and installed for about $360.00
  3. Feb 16, 2015 at 4:51 PM
    #43
    Gabassman
    Tyler
    Georgia
    Just a quick search I keep seeing $100
  4. Feb 16, 2015 at 6:16 PM
    #44
    POOLGUY
    JEFF
    ALABAMA
    sounds good to me.
  5. Feb 16, 2015 at 6:42 PM
    #45
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    How much oil are you losing? Like a quart a day, or a quart every six months?
  6. Feb 16, 2015 at 6:52 PM
    #46
    Add2481TRD
    Add2481TRD Well-Known Member
    J
    Georgia,SW
    15PreRunnerTRDOR
    Bull Bar, Tonneau Cover
    My former 2004 4Runner (4.0L) had a small leak at the crankshaft seal. At the time there was a TSB out concerning issues with the crankshaft finish. Of course my VIN was not part of the group listed. The leak was minor so I just monitored it until I sold it for the 2011 we have now. I cleaned the area with de-greaser at every oil change so that I could monitor the leakage rate. I told the new owner to keep an eye on it just in case. The leak did not change much during the time I owned it.
    Hope you find the problem and it's easy to correct.
  7. Feb 17, 2015 at 4:26 AM
    #47
    Gabassman
    Tyler
    Georgia
    Couldn't tell you it's only been leaking for about a month. K removed the serpentine belt on January 1st snd it started after that some time.
  8. Feb 17, 2015 at 4:27 AM
    #48
    Gabassman
    Tyler
    Georgia
    I feel mine is a pretty substantial leak. All in the passenger wheel well and steering components.
  9. Feb 17, 2015 at 4:33 AM
    #49
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Keep the oil topped off until you can get it fixed.
  10. Feb 17, 2015 at 4:36 AM
    #50
    Clearwater Bill
    Billy
    Largo Florida
    You are never 'forced', and yes you have choices.
    You can find a reputable independent mechanic. Typically their hourly rates are about 1/2 the glam dealer shops. And they can buy OE parts, at a discount, if that's what's needed to effect a proper repair.
    For me, I only use a dealer shop for warranty work or recalls.
  11. Feb 17, 2015 at 6:58 PM
    #51
    Add2481TRD
    J
    Georgia,SW
    15PreRunnerTRDOR
    My leak would work its way down to the oil pan area and slightly past it over time. The off the shelf "purple power" cleaner does a fairly good job of cleaning the areas if you let it sit for a few minutes. With the engine slightly warm, it should remove the oil build up and help you see the origin of the leak at least. Good luck...
  12. Feb 17, 2015 at 7:17 PM
    #52
    Gabassman
    Tyler
    Georgia
    Thanks. I havent even tried to clean it yet. Ive been checking it every cou[ple of days.
