Help identifying this part with leak?
Discussion in '4 Cylinder' started by ivtoyota, Feb 3, 2015.
  1. Feb 3, 2015 at 9:21 AM
    ivtoyota
    ivtoyota [OP] Member
    rick
    san diego
    basic 4 banger tacoma
    hello guys.. Toyota guy since 1994.. now I own a 2005 Tacoma 4c regular cab. I noticed a leak every morning right around the middle of engine on driver side of engine. at first I thought it was dew/condensation but this morning decided to look at at better and water is leaking from this location, not sure what its called picture attached. please help in identifying this part I need to replace. thanks guys!! sorry photo is upside down
  2. Feb 3, 2015 at 9:24 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Maybe waterpump?
  3. Feb 3, 2015 at 10:46 AM
    ivtoyota
    rick
    san diego
    after searching the internet I found that it might be the "coolant bypass pipe".. will do more research on this but this looks like my problem...
  4. Feb 3, 2015 at 10:50 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    It's definitely coolant. The red crust gives it away.
  5. Feb 3, 2015 at 11:20 AM
    Indy
    Indy Master of all I survey.
    Tough angle, return from the heater core?
  6. Feb 3, 2015 at 7:55 PM
    tacoma4
    tacoma4 Well-Known Member
  7. Feb 3, 2015 at 8:14 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    If you check behind the fan pulley, see if there is coolant leaking out of the weep holes of the water pump. That is where mine was leaking and I had to replace the water pump.
  8. Feb 4, 2015 at 11:53 AM
    ivtoyota
    rick
    san diego
  9. Feb 5, 2015 at 2:15 PM
    ivtoyota
    rick
    san diego
    hey guys, is there a link to where I can get specs to how much to torque the intake manifold bolts? I saw something on line where it even showed what bolt to tighten first but cant find that page..
  10. Feb 5, 2015 at 2:22 PM
    ivtoyota
    rick
    san diego
    I think I found it.. half way down the page... what do you guys think, is it legit?
  11. Feb 9, 2015 at 9:20 AM
    ivtoyota
    rick
    san diego
    well guys I got it done! truck is back in action... took about 5 hrs total. only hard part was small pipe near firewall that was hard to reach.. long needle nose pliers helped.
