HELP ignition switch jammed
Discussion in '1st Gen. Tacomas (1995-2004)' started by Brian carparty, Oct 19, 2009.
  1. Oct 19, 2009 at 2:17 PM
    Brian carparty
    Brian carparty [OP] New Member
    brian
    manassas
    stock 97 taco <green>
    ok so i put my key into the ignition and it turns half way just enough to get the radio goin and then it stops almost as if it is catching on something solid anyone have suggestions on how to take it apart and possible fix it myself and save some cash?...:confused:
  2. Oct 19, 2009 at 2:21 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Turn your steering wheel slightly while turning your key. The wheel lock is probably holding things in place.
    Welcome to TW, btw.
  3. Oct 19, 2009 at 2:22 PM
    mjp2
    NJ
    Wait, it turns to the Run position but not to Start? That's definitely odd. Someone else might have some ideas.
  4. Oct 19, 2009 at 2:36 PM
    Brian carparty
    brian
    manassas
    ya it gets half way its not cause the steering wheel is locked something is actually wrong with it
    i have everything taken apart and im trying 2 avoid dismanteling it because i might not be able 2 put it back 2 gether
  5. Oct 19, 2009 at 2:40 PM
    mjp2
    NJ
    Well, it's almost 13 years old. It may just be time for a new ignition tumbler.
