HELP in purchasing-please!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by dtuck, Nov 20, 2015.
  1. Nov 20, 2015 at 4:12 AM
    dtuck
    dtuck [OP] Member
    Don
    2001 Tacoma Double Cab SR5 PreRunner
    Hey everyone. First post. Looking at a 2001 double cab SR5 PreRunner for my son today. Have always loved the look of the first gen tacomas and feel it will be a killer first truck for him. The truck is listed in South Florida Craigslist for sale in Plantation, FL for $7,000. She has 227K miles, one owner, his brother works for a local toyota dealership as a mechanic and it seems to have all major work up to date. What should I be looking for when I inspect this truck?? What seems to be the biggest issues in a late model Tacoma with high miles?? What would you pay for this Tacoma?? Any input would be greatly appreciated!!!
    Thank you!!
  2. Nov 20, 2015 at 10:19 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    price sounds fair, mileage sounds high but not terrible. if its the only one you have found its not a bad deal but to be honest, I would keep looking to find one with 100k-125k miles on it. it will likely be priced from $8k-$9k and maybe as high as $10k-$11k depending on condition but its a much better long term option if the idea is to keep the truck for another 10-15 years.
    anything over 150k miles you have to think of possible engine wear issues and even though these engines can go 400k miles, that is only if well maintained with regular timely oil changes and driven "respectively" as in not dogging it.
    as for what to look for, RUST frame rust is the #1 killer for these truck and they rust from the inside out so by the time you see serious rust the frame has been compromised. most northern trucks have rust issues from road salts but since its in florida, the salt there can be a concern especially if they used the truck to back boat trailers into the water.
    opteron likes this.
  3. Nov 20, 2015 at 10:44 AM
    dtuck
    dtuck [OP] Member
    Don
    Keakar--thank you for the reply. Just found this site and could have searched a little more before posting first question. I want to this truck to last my son about 4-5 years. Plan on modding it out a little bit. Taking a look at 4pm today. We will see how it goes. This site is fantastic!!! Ton of information and the search function works really well. Thanks again, any addl. comments please send em.
    Don
  4. Nov 20, 2015 at 11:02 AM
    keakar
    karl
    louisiana
    if its a v6 3.4 engine check on the last time and mileage of the timing belt replacement. there should be a sticker right on the timing belt cover.
    it should have it done at least every 100k miles and the kits costs around $250 and should be bought here http://www.ebay.com/itm/190521450224?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT its all 100% oem totyota parts used and it takes some time to do but it isn't hard job. if you have to pay someone to do it expect it to cost about $500.
    if its a 4 cylinder, they have timing chains that virtually never go bad or need adjustment but they all have unsolvable rough idle in gear issues that is not because it needs a tune up but because its just the nature of the 4 cylinder engines.
    that's about all I can think of other then the obvious things you check
  5. Nov 20, 2015 at 7:07 PM
    dtuck
    dtuck [OP] Member
    Don
    Decided to pull the trigger at 7k. The previous/original owner took incredible care of her. Seems to be having a hard time selling her. Extremely clean inside and out. Real solid little truck. Do you suggest putting a cold air intake in her??
  6. Nov 21, 2015 at 8:24 AM
    keakar
    karl
    louisiana
    no, they are a waste of money.
    if its a 4 cylinder then I would do the fender mod where you remove the air fitting that goes into the fender and cut the 90 off of the back side of it so it gets more air and doesn't have to suck from the restricted ductwork inside the fender.
    if its a 6 cylinder, I would leave it stock since any intake mod will just increase noise it makes but wont give you any benefit from doing it.
    in either case I would put in a permanent air filter so it breathes better and clean the MAF sensor and throttle body and replace the plugs and pull the wheels to check the condition of the brakes as your maint items to do with any used vehicle,
  7. Nov 21, 2015 at 9:18 AM
    BRUSHCREEK
    BRUSHCREEK Active Member
    Travis
    west central Illinois
    02 PreRunner Limited TRD
    Welcome dtuck congrats on your sons new Tacoma. Have any pics?
  8. Nov 21, 2015 at 9:23 AM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    :worthless:
    Welcome to the jungle.
  9. Nov 21, 2015 at 1:02 PM
    dtuck
    dtuck [OP] Member
    Don
    Thank you for the welcome. How do you post pics?? Picking up on Monday. It has the 3.4 6. The guy I am buying her from is meticulous. All oem parts. All receipts. Almost didn't want to sell her to me because he thought my son may be to rough on her. Replaced AC 6 months ago. Did a bunch of other stuff. When I pick her up I will post what he has done, you guys will understand it a lot more then I do. What is the MAF sensor and throttle body?? Thank you so much for the cold air intake advice keakar!!! I am looking for a lockable bed cover due to my son being a hockey player and fisherman. Did him to be able to securely leave that crap in the bed. Seems like there aren't a lot of covers available first first gen Tacoma's. Bakflip seems to be the only one I can find. Any suggestions???
  10. Nov 21, 2015 at 1:15 PM
    tacomatrd22
    tacomatrd22 TRD SuperCharged Tacoma
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    FlowMaster Super 44 2" lift Gray wire Fog light
    If you have a smart phone you can take a picture of the truck and just push upload a file and choose from your library. But I like how the owner took care of the truck. And your throttle body is where your air intake leads into and goes towards your intake. I will post pictures give me a min to find or upload the files.
  11. Nov 21, 2015 at 1:20 PM
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    Your son's truck won't have what's on top of my engine. But your throttle body is located left where the 2 cable wires lead to. It's not that hard to remove.
    Your MAF sensor is right in your intake tube. As shown in this picture above the flash light.
  12. Nov 21, 2015 at 1:45 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Good choice, it will last him beyond 4-5 years if he takes care of it! Get him through high school and college easy.
  13. Nov 21, 2015 at 3:03 PM
    BRUSHCREEK
    Travis
    To bad we werent closer I would make you a killer deal on a snugtop bed cover for a double cab.
  14. Nov 21, 2015 at 6:13 PM
    dtuck
    dtuck [OP] Member
    Don
    How do I clean the MAF and throttle body??
    Thank you for all of the info!!!!!
  15. Nov 21, 2015 at 6:14 PM
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    Get MAF cleaner and get throttle body cleaner. You will see them at O'Reilly's and such.
  16. Nov 21, 2015 at 6:25 PM
    dtuck
    dtuck [OP] Member
    Don
    Just spray it on?? Also have an engine light on due to O2 sensor when po did diagnostic for me. Am going to try pulling 20 amp fuse and look for reset or should I unscrew and clean sensor?
  17. Nov 21, 2015 at 7:16 PM
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    Take it off and then spray it. You don't want to spray it while the throttle body and MAF is still on the truck.
  18. Nov 21, 2015 at 8:44 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
  19. Nov 22, 2015 at 10:08 AM
    dtuck
    dtuck [OP] Member
    Don
    Man, you guys are the sh&$!! Thank you to everyone with your responses. I have wanted a first gen Tacoma for the last 25 years. Coolest truck out there, imp. I have always driven a company car, very lucky in that respect, but now can trick out a Tacoma for my son. Killer!!!
  20. Nov 22, 2015 at 6:11 PM
    keakar
    karl
    louisiana
    the one down side to this website is the guys here keep giving you great ideas and you always end up wanting to spend money buying cool stuff for your truck lol
