help in the fuse box department...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlueTaco07, Jun 10, 2011.
  1. Jun 10, 2011 at 3:55 PM
    BlueTaco07
    BlueTaco07 [OP] Super Mod!
    Cody
    Panama city, Florida
    Looking
    Okay im young so dont laugh but I have two led interior lights im installing today. both led strips has a positive and negative, so I joined both posi's and both negatives and now i have connected speaker wire to each and ran it to the fuse box. How do I connect to a fuse box???
  2. Jun 10, 2011 at 4:09 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
  3. Jun 10, 2011 at 4:50 PM
    justinhw
    justinhw Well-Known Member
    Turlock, CA
    06 Regular Cab 4x4 2TR-FE
    Yah fletch aka's suggestion is good, I would use that (it adds a circuit in parallel to whatever fuse you plug into) and pass it through the grommet in the firewall with the rest of the wiring harness to get into the cab.
    Your wiring would be:
    + (hot) "littelfuse" -> through firewall into cab -> led strip 1 -> led strip 2 -> ground somewhere in the cab.
    Just be cautious that the wiring behind whatever fuse you tap into is going to take the load of both circuits. Depending on the current requirements of your led strip it may/may not be an issue.
  4. Jun 10, 2011 at 4:52 PM
    justinhw
    Turlock, CA
    oh.. haha and yah like whippersnapper02 said you would probably want to pass it through a switch or relay so you can turn it on/off. Easiest location in my opinion would be left kick panel or close to it.
  5. Jun 10, 2011 at 5:11 PM
    JKD
    JKD Well-Known Member
    Depending on location, people often wire aux lights to the dash light circuit.
  6. Jun 10, 2011 at 7:16 PM
    BlueTaco07
    Cody
    Looking
    will speaker wire effect anything?
  7. Jun 10, 2011 at 8:23 PM
    JKD
    It might not be designed to carry much current. It depends on how much current your LED strips draw.
