Help In Understanding Dual Battery Setup w/ Solar
Discussion in 'Technical Chat' started by yellowdogpaddler, May 11, 2018.
  1. May 11, 2018 at 4:55 AM
    yellowdogpaddler
    yellowdogpaddler [OP] Well-Known Member
    doug
    2018 DCLB OR
    GoFast Camper, Faulken WildPeak, TRD Pro (4Runner) Wheels), Goal Zero Yeti/Solar
    Is there a thread that has a written explanation and diagram of the recommended electronic components and electrical flow of a dual battery setup and solar? I would like to learn and understand the theory as much as the practical knowledge in setting up a dual battery setup.
    I did find a great thread on member's setups... https://www.tacomaworld.com/threads...ts-see-them-multiple-batteries-thread.295653/
    Parts of the puzzle are DC-DC unit, Isolator, MPPT... I have very little if any electrical knowledge and I would like to understand how this works thoroughly and what items are required before undertaking this project.
    What I do know is the items that I want to add to my setup will require power to run them- "draw" and that there will need to be a source to deliver the additional power requirements and a way to "charge" the source.
    greeneggsnspam likes this.
  2. May 14, 2018 at 2:17 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    The best place to start is figuring out just what devices you need to run.
    Do you also need a Inverter to run AC only devices ??
    Do they need to run 24/7 /365 or just a few days
    Do you need to add more things down the road ?? .
    You don`t want to be at the limit of your system and find out you need to add more devices
    This is the hard part .
    The rest is just simple DC circuits and hardware
  3. May 14, 2018 at 2:39 AM
    ilubtimmyhos
    ilubtimmyhos Brewer
    Adam
    Haymarket, VA
    2012 Blue Tacoma 4x4 Pre-Runner
    4x4 Conversion w/ FJ T-Case, King 2.5 Extended Travel Coilovers w/ JBA UCAs, King 12" 2.0 Smoothies w/ BAMF relocate in the rear, OME Dakar leaf pack, 4.56 gears w/ ARB air locker, Archive Hammer Hangers w/ crossbar brace, ARB Snorkel, Custom Bed cap w/ Roofnest Sparrow XL, Retrofit Headlights, Wrapped in 3M Satin Perfect Blue
    Hopefully our conversation on Friday cleared all of this up for you.
