Help! Lce header or regear after lift and tires????
Discussion in '5 Lug' started by Thefoot44, Jan 22, 2016.
  1. Jan 26, 2016 at 6:09 AM
    TownvilleTim
    TownvilleTim Well-Known Member
    Tim
    Townville, SC
    07 ACLB SR5 2.7L 2015 DCSB SR5 V6 4x4
    TRD Pro Suspension, SOS sliders, SR8 Wheels, Duratracs, ARE shell
    I have about 7k miles on them wit no issues at all. I had a seasoned racing pro do it, and I really don't expect any either. There was no extra labor charge to install the Truetrac because he had it apart anyway. I ordered it from Summit and took it to him. Just be sure to get someone that really knows what they are doing because there's a setup involved. Its not just replacing parts..
    Thefoot44[OP] likes this.
  2. Jan 26, 2016 at 2:15 PM
    HackD
    HackD Marching to the Beat of a Different Drum
    William
    Hamilton, Ontario, Canada, eh?
    2010 Base 4x2, 2.7L, 5 speed manual 5-lug Slug
    Gone over the Top for a 5-lug..
    *just a note for present and future readers interested in the 5-lug re-gear options.*
    Discussions regarding re-gearing in the thread thus far, appear to be automatic transmission focused.
    The below comment relates to second gen 5-lugs only.
    To clarify confusion - The Auto's 3.58 final gearing shares gear parts that are easily sourced from elsewhere. Replacement components are easily sourced in terms of alternative gearing ratios. The Standard's 3.307 final gearing shares no such commonality for replacement components. You are sourcing a complete replacement third member - either a non-trd 4x4's 4.10 will do, or an aftermarket replacement from ECGS or similar. A few more dollars involved, including covering a core charge (in the case of ECGS, $400 .. they don't want your 3.307 paper-weight).
    ECGS example: http://eastcoastgearsupply.com/i-788575-tacoma-8-4-non-eld-t100-tundra-3rd.html
    Nathan and Thefoot44[OP] like this.
  3. Jan 26, 2016 at 3:28 PM
    TownvilleTim
    Tim
    Townville, SC
    Good point!
  4. Jan 26, 2016 at 5:17 PM
    Bulldogfandan
    Bulldogfandan Member
    Daniel
    2013 Black Regular Cab 2wd
    Thanks for the info. Is it as simple as swapping the third member, or do you have to swap the actual gears as well? stupid question, but i'm new to all of this.
  5. Jan 27, 2016 at 5:31 PM
    HackD
    William
    As far as i know, it's a pretty straight forward component swap. You are taking out the differential assembly, and replacing with a new assembly, rather than going into the guts of it to replace and re-shim replacement components.
    This is as far as I have looked into it, up to this point. For the manual transmission 5-lug, it isn't a cheap fix. My current 225/75R16 tires at 29.3" aren't causing me acceleration issues. If i go bigger, i'll reconsider then.
  6. Jan 28, 2016 at 9:03 AM
    Rolis12
    Rolis12 Well-Known Member
    Rolis12
    San Diego
    2015 5lug access auto
    Goodyear Wrangler TrailMark 31's. F.B's 2.75" spacer, TRD rear shocks, stub antenna, ripped out charcoal filter added AFE dry, Chrome grille, upgraded to SR5 sun visors, variable wipers, backup camera, HID DDM 35w 5000kv, ebay fogs w/yellow LEDs.
    I'm still very confused on what i can use from other tacos to regear my 2015 auto to the 4.10 setup
  7. Jan 28, 2016 at 10:16 AM
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    I think east coast gear supply will sell you the unit you need to change the ratio to 4:10. not absolutely sure on this. Contacting them cant hurt?
    Rolis12[QUOTED] likes this.
  8. Jan 28, 2016 at 12:12 PM
    hoenah808
    hoenah808 Well-Known Member
    Trent
    Honolulu, HI
    '14 AC sr5 4x4
    Rolis12[QUOTED] and HackD like this.
