Help: Lift, Tires, Rims and what not.
Discussion in '1st Gen. Tacomas (1995-2004)' started by gatorboyy13, Jun 26, 2011.
  1. Jun 26, 2011 at 6:44 PM
    gatorboyy13
    gatorboyy13 [OP] Well-Known Member
    Brian
    Corvallis, OR
    2016 TRD OR DCSB Black
    CustomCarGrilles Small Perf & "TOYOTA" Grille Insert CaliRaised 31" Light Bar w/ ApexFab Stealth Mounts Header Rail w/Bike Mount
    I know i have asked alot, but im for sure doing it this time! Got the money got everything!
    I have an '01 PreRunner, mostly stock
    LIFT:Well i want a 300$ or under lift from toytec. which is best for me?
    TIRES and RIMS:
    Im getting 285/75/R16 all terrains, id like to get some cheap cragar soft 8's. I really just want cheap steelies, know a good place to find them? and what are the exact measurents i need for this tire.
    MISC:
    what else would i need?
  2. Jun 26, 2011 at 6:47 PM
    tacotrd647
    tacotrd647 Resident "dude"
    Caleb
    Ridgeway, Iowa
    02 Prerunner SR5 TRD
    KMC Enduro Wheels, 265/75/16 toyo open country at2
    Well...an OME lift would probably be your best bet for running 285's without rubbing issues. I'm not sure on the price of the OME set up though.
    For cheap steelies, try 4 wheel parts. They have good prices on wheels.
  3. Jun 26, 2011 at 8:53 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Good luck finding a decent lift for $300ish...
    If you're trying to pinch pennies, you could go for 15" rims. They cost less then 16's including comparable tire sizes.
  4. Jun 27, 2011 at 1:14 AM
    CHPTR11
    CHPTR11 Team Impulse Red
    Dan
    Pacific NW
    2004 TRD Tacoma
    OME, Hankook, ARB, SCS
  5. Jun 27, 2011 at 1:29 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    Lifts are something that you can put together for cheap, but the best thing to do would be to save a little more and go for the good stuff... not 1000's, but more than only $300. You might regret a cheap lift in the long run
  6. Jun 27, 2011 at 12:21 PM
    gatorboyy13
    Brian
    Corvallis, OR
    So that is my best option for that price range? I just dont have the kind of money but i want it done now. and the tires are that cuz im getting a good deal on them
  7. Jun 27, 2011 at 12:38 PM
    firefightermdc
    firefightermdc Well-Known Member
    el paso, tx
    01 Tacoma SR5 4x4 TRD
    Pretty much..you'd do better to save a little more and do an ome lift. Trust me that a cheap lift only Starts out inexpensive...
  8. Jun 27, 2011 at 12:40 PM
    CHPTR11
    Dan
    Pacific NW
    2004 TRD Tacoma
    Well that kit comes with new shocks.
    Your other option is 5100's front and rear with blocks or AAL which will run you around $350. I would highly recommend the 5100 w/ the AAL, but you might rub if you plan on doing any off roading. Talk to Marco at Downsouth Motorsports, they're a vendor here. I just bought my OME kit fron them and they have free shipping.
    If you are set on the 285's I'd just run your stock wheels with some spider trax wheel spacers (approx $200).
    Spacer kits can be bad news, but lots of people run them with no problems.
    The Toytec kit is a spacer lift, while the 5100's use the shocks to achieve the desired lift (but give you a maximum of 2.5" of lift, while the spacers will give you the full 3").
  9. Jun 27, 2011 at 12:42 PM
    LBCdan
    LBCdan I got tiger blood.. WINNING
    Dan
    Long Beach , CA
    2012 MGM DCSB TRD SPORT
    Pioneer 4000NEX , grab handle GPS mount, Bakflip tonneau, OME 885, Bilstein 5100s, Wheelers 1.5" AAL
    4wheelparts usually has good wheel & tire packages and they mount and balance for free.
