Help locating fuses
Discussion in '3rd Gen. Tacomas (2016+)' started by lilldill, Nov 1, 2015.
  1. Nov 1, 2015 at 5:31 AM
    lilldill
    lilldill [OP] Well-Known Member
    Dylan
    Myrtle Beach
    2016 White TRD Sport
    where is the fuse box located in the 2016 tacomas and how do I remove the cover. sorry I am new to trucks lol
    ChadsPride likes this.
  2. Nov 1, 2015 at 5:44 AM
    Mike330R
    Mike330R Well-Known Member
    Far West Phoenix
    '16 DC Offroad w/ stuff
    One under the hood and one in the dash, drivers side.
  3. Nov 1, 2015 at 5:53 AM
    LiveFreeOrDie2015
    LiveFreeOrDie2015 Well-Known Member
    York PA
    15 DCSB TRD OFFROAD
    3in lift,Fox suspension,chaos UCA,AAL,leer 180 topper,SilverStar zXe headlights & fog lights,BAMF kickout sliders,Mobtown full skids,Pelfreybuilt center hoop, Pelfreybuilt Gas Tank Skid,50" curved LED light bar, Hood scoop LED, Tran cooler and fan,Oil Catch can,LED Strip lights under hood & Bed,
    Gen 3s don't have fuse boxes anymore they've been upgraded to flux capacitors image.jpg
    C-Diddy, kgilly, Acivichb and 34 others like this.
  4. Nov 1, 2015 at 5:58 AM
    lilldill
    Dylan
    Myrtle Beach
    I blew the fuse for my dome and map lights, which fuse box would that be in
  5. Nov 1, 2015 at 6:02 AM
    LiveFreeOrDie2015
    York PA
    15 DCSB TRD OFFROAD
    All the fuses are labeled look under the lid it should tell you.........it even has a fuse puller
    How did you blow a fuse?
    0uTkAsT likes this.
  6. Nov 1, 2015 at 6:26 AM
    lilldill
    Dylan
    Myrtle Beach
    which one would it be
    protaxidermist likes this.
  7. Nov 1, 2015 at 6:26 AM
    lilldill
    Dylan
    Myrtle Beach
  8. Nov 1, 2015 at 6:27 AM
    lilldill
    Dylan
    Myrtle Beach
    I was putting blue LEDs in my map and dome light. I had 2 of 3 done. I was putting the 3rd one in and it snapped in half and the wires touched weird and they flickered and they all shut off. none will work anymore
  9. Nov 1, 2015 at 6:29 AM
    Mike330R
    Far West Phoenix
    Not sure, you may have to check them all. Either with a meter or pull each one out and look.
    There is also a small panel under the dash on the drivers side. I forget exactly where.
  10. Nov 1, 2015 at 6:32 AM
    lilldill
    Dylan
    Myrtle Beach
    I found the one under the hood after looking in the manual lol. can you tell which fuse it would be by the diagram I posted?
  11. Nov 1, 2015 at 6:46 AM
    LtTaco
    LtTaco Well-Known Member
    Tennessee
    2016 SuperWhite Limited 4X4
    I got my money on the 7.5 Amp fuse labeled "dome". :D
    Under dash drivers side.
  12. Nov 1, 2015 at 7:35 AM
    Frank_Zuccarini
    Frank_Zuccarini Obscure Member
    Frank
    Chicagoland
    AC-TRD-OR-4x4-Barcelona Red
    Nicely done, LtTaco.................................. Frank
    BSFord and RNJNKE like this.
  13. Nov 1, 2015 at 7:37 AM
    LtTaco
    Tennessee
    :humble:
  14. Nov 1, 2015 at 8:44 AM
    lilldill
    Dylan
    Myrtle Beach
    thanks LtTaco, how do you remove the panel to get to the one under the dash
  15. Nov 1, 2015 at 8:52 AM
    motomaster132003
    motomaster132003 Well-Known Member
    2016 Tacoma TRD OR DCSB
    Just for future reference, it's always best to disconnect the ground on your battery before working on anything electrical in the truck so that something like this doesn't happen. I get lazy and forget to do it too, so I am guilty as well.
  16. Nov 1, 2015 at 8:59 AM
    lilldill
    Dylan
    Myrtle Beach
    good to know. thanks motomaster
  17. Nov 1, 2015 at 9:00 AM
    lilldill
    Dylan
    Myrtle Beach
    how do I remove the cover to get to the fuse
    Greg.Brakes.Tacos likes this.
  18. Nov 1, 2015 at 9:04 AM
    LtTaco
    Tennessee
    Look under there. I thought it looked pretty obvious.
    Maybe you should not be adding mods to your electrical system if you can't figure out how to change a fuse after i showed you exactly where it was.
    Maybe it's your truck trying to reject those hidious blue LED you are installing. :D
  19. Nov 1, 2015 at 9:20 AM
    Gatordog
    Gatordog Well-Known Member
    Florida
    18 TRD SPORT DCLB4x4
    Careful with your witty sarcasm humor truths! You might get ignored..... LOL>...... great picture of what fuse it should be and very helpful for sure!
  20. Nov 1, 2015 at 9:41 AM
    LtTaco
    Tennessee
    I put a small blade screwdriver in the hole and popped it open by prying it slightly. Fuses underneath cover.
