Help me analyze my alignment results
Discussion in 'Suspension' started by DNG, Dec 3, 2011.
  1. Dec 3, 2011 at 6:01 PM
    DNG
    DNG [OP] Well-Known Member
    Orange County, CA
    White 01 DC PreRunner
    Front Left
    Camber (Specified Range -0.1 - 0.6): 0.1 degrees (before: 0.1)
    Caster (Specified Range 1.8 - 3.3): 3.9 degrees (before: same)
    Toe (Specified Range -0.07 - 0.13): 0.07 degrees (before: 0.14)
    SAI (Specified Range 10.3 - 11.8): 10.4 degrees (before: same)
    Included Angle (Specified Range 9.3 - 12.3): 10.5 degrees (before: same)
    Front Right
    Camber (Specified Range -0.1 - 0.6): 0.7 degrees (before: 0.6)
    Caster (Specified Range 1.8 - 3.3): 3.8 degrees (before: same)
    Toe (Specified Range -0.07 - 0.13): -0.03 degrees (before: -0.24)
    SAI (Specified Range 10.3 - 11.8): 9.9 degrees (before: 10.0)
    Included Angle (Specified Range 9.3 - 12.3): 10.6 degrees (before: same)
    How does it look?
    The guy at the shop said that my camber adjustments were "maxed out" due to my lift (2.5" with Camburg coilovers and UCAs), and couldn't make them any better.
    My car pulled to the right when I brought it in, but it didn't get any better. Is that caused by the camber and/or caster on the right, front tire?
  2. Dec 3, 2011 at 6:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Right Camber needs to be brought down to near what the other side is.....You have alot of Caster. Have it dropped to about 2.6*
  3. Dec 3, 2011 at 6:26 PM
    DNG
    Orange County, CA
    Is it true what he said about camber adjustment being "maxed out" because of my lift?
    How bad it 3.9 degree caster?
  4. Dec 3, 2011 at 7:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I dont think so. You want LESS camber on the right side. Not more. And you want less Caster.
  5. Dec 4, 2011 at 4:36 PM
    DNG
    Orange County, CA
    bump
  6. Dec 4, 2011 at 4:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Why the bump? I just gave you the info you needed.
  7. Dec 4, 2011 at 4:48 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    hold tight man let me take a peek
  8. Dec 4, 2011 at 4:58 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    ok the reason its pulling right is the camber. u have too much camber on the right side. a difference (or total) of .5* or more will cause a pull. what needs to happen is the right side needs to come down on both camber and caster. the left side needs to drop caster to try and match where the right side ends up. but i like where the camber is on the left side. dont pay attention to IA or SAI they wont be in when u lift a truck. id bring it to a shop who knows how to align lifted trucks. also make sure the guy didnt mean that u have a cam or eccentric thats SIEZED rather than "maxed out". two completely different things. I align lifted Toyotas almost everyday including memebers on here....lmk how this goes pm me if u wanna....
  9. Dec 4, 2011 at 5:29 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Bump
    Anyone got an answer ?
    Anyone at all ?
  10. Dec 4, 2011 at 5:34 PM
    T-Rex266
    T-Rex266 Moderator Moderator
    Elon
    Lol! ^
  11. Dec 4, 2011 at 5:44 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    really? ha
  12. Dec 4, 2011 at 5:48 PM
    OZ-T
    Peter North
    British Columbia
    You know I'm just kidding
    :cookiemonster:
