Help me build my a moderate sound system
Discussion in 'Audio & Video' started by malander, Feb 24, 2012.
  1. Feb 24, 2012 at 9:54 PM
    malander
    malander [OP] Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    I'm first going to start out by saying that I am electrically retarded. But here it goes anyway.
    About a year ago I got a Pioneer 5200hd head unit and it was nice and all but I wanted more. A friend of mine helped me put in some polk audio db571 speakers up front and I thought that would be enough. I don't want to pay another hundred bucks for a set of rear speakers but I want some that will match the polks pretty well. If worse comes to worse I'll save up and get them but I also have the opportunity to get a 10" enclosed TS-SWX251 sub from pioneer for about 70 bucks. All I would need is an amp. I have no idea if this will fit behind my backseat or under the passenger seat but I can measure it out. If not I'm going to have to think about some creative spot to put it. No idea what type of amp I should run to the sub or how to hook that up. Also wondering about amping speakers. Any help is appreciated as most of this stuff really makes no sense to me. Thanks in advance.
  2. Feb 24, 2012 at 9:56 PM
    malander
    max
    01 limited trd 4x4
    Just stole this off crutch field for info on my HU to see if it helps at all
    RMS Power Output 14 watts
    Peak Output 50 watts
    RMS Power Bandwidth 20-20kHz
    Preamp Outputs 4-channel
    Sub Preamp Outputs No
    Switchable Rear Preamp Outputs Yes
    Preamp Voltage 2.2 volts
  3. Feb 24, 2012 at 9:57 PM
    malander
    max
    01 limited trd 4x4
    And for my Polk Audio db571s
    Sensitivity 93 dB at 1 watt
    Frequency Response 52 - 22k Hz
    RMS Power Range (Watts) 6-60
    Peak Power Handling (Watts) 180
    Impedance (Ohms) 4
  4. Feb 24, 2012 at 10:00 PM
    malander
    max
    01 limited trd 4x4
    And the sub I can get for pretty cheap
    Woofer Size (inches) 10
    Woofer Material IMPP
    Enclosure Type Sealed
    Color Black
    Pieces in System 1
    Width (inches) 18-7/8
    Height (inches) 11-15/16
    Depth (inches) 5-7/8
    Second Depth (inches) 5-7/8
    Connector Type Spring post
    Frequency Response 20-114 Hz
    Power Range (Watts RMS) 50-200
    Maximum Wattage 800
    Sensitivity 91 dB
    Impedance 4 ohms
  5. Feb 24, 2012 at 10:07 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    If you add a sub, there's no reason to worry with rear door speakers. I have mine unhooked.
  6. Feb 24, 2012 at 10:09 PM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    your HU doesnt have sub preamp outputs!?!?!?
    Thats kinda shitty
  7. Feb 24, 2012 at 10:10 PM
    Maverick904
    Kameron
    Northeast Florida
    and to what he said. this is pretty good info.
    I have my fader favored to the front anyways. no need to run the rear speakers hard if nobody sits back there.
  8. Feb 24, 2012 at 10:41 PM
    t4daddy
    North Alabama
    I'd go with a different HU if it don't have pre outs, WTF? You can get away with a half-assed set of components in the front doors, driven off a decent HU, and a sub or even two small (eight inch) and a mediocre amp driving it/them.
  9. Feb 25, 2012 at 7:51 AM
    malander
    max
    01 limited trd 4x4
    Hmm head unit wasn't in the plans but I kinda don't like the one I have anyway. I might try and get some of the same speakers for the rear for cheap and just amp the speakers and wait on the sub though for now. I like sounds coming from all around me and I do drive around with a bunch of people fairly often so it might be justifiable. If I were to amp 4 speakers (the same polks I have) what should I look for specification-wise?
  10. Feb 25, 2012 at 10:36 PM
    DevL
    DevL Well-Known Member
    The front seats block most of the rear speaker output.
