Help me decide on which Icon set-up
Discussion in 'Suspension' started by ToeKneeSock, Nov 30, 2014.
  1. Nov 30, 2014 at 11:09 AM
    ToeKneeSock
    ToeKneeSock [OP] Member
    Tony
    San Diego, CA
    heh
    Hey all,
    Looking to jump on the black Friday deal on Icon suspension, but I'm torn between two set-up. I don't do any form of off-roading at the moment. I do however want to run bigger tire (275-65R18) and a smoother ride.
    $1457 - Icon Stage 1 w/ Icon AAL
    $1634 - Icon Stage 2
    The only difference I see is that Stage 2's rear shock has the remote reservoir. Is that really needed? I can save $177 that can be spent elsewhere on the cheaper set-up .
    Tony
  2. Nov 30, 2014 at 11:24 AM
    CruisinE2W
    CruisinE2W New Member
    CA
    2010 Tacoma PreRunner SR5
    Do you have any desire to start hitting some trails and taking the truck off road? If so, it might be a good investment. You're spending a decent amount already, why not get some extra performance at all four corners? Even with the res. the shock is a bolt-on piece in the stock location so it's not like it requires a whole lot of extra work.
    That said, Stage 1 is still an upgrade and if you would rather spend the extra coin elsewhere, go for it.
    FWIW, I have Stage 2, Camburg Ball Joint UCA's, and 265/70/17 Terra Grapplers on my commuter/weekend warrior and could not be happier. Completely different truck after the suspension went on. :cheers:
  3. Nov 30, 2014 at 11:41 AM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    I have the stage1 w AAL..LR UCA I love the way my truck rides soooo much better than stock
  4. Nov 30, 2014 at 11:55 AM
    ToeKneeSock
    Tony
    San Diego, CA
    heh
    I would like to go on trail/off-roading at some point since I got the 4x4, but in what scenario does the remote reservoir become beneficial over the non version ones? They do look cool tho, but at an addition $177 I can probably get me some WeatherTech floor mats.
  5. Nov 30, 2014 at 7:05 PM
    303tacoma
    Rebecca
    The remotes hold more liquid to keep the shock cooler
  6. Nov 30, 2014 at 10:29 PM
    TacoBrah
    TacoBrah Well-Known Member
    Sean
    Icon stage 1, 255/85/16 KM2
    Same and I love it.
    You should be fine without resis.
  7. Dec 2, 2014 at 2:38 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Deff get the resi......your in Cali where you'll need it with that terrain.
  8. Dec 2, 2014 at 9:46 AM
    ToeKneeSock
    Tony
    San Diego, CA
    heh
    Thanks for all the input. I ended up getting just Stage 1 without the AAL. Will just level it out for now and hopefully it's a much nicer ride.
