Help me increase my Tacoma's fuel range
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mattb85, Nov 9, 2017.
  1. Nov 9, 2017 at 2:16 AM
    Mattb85
    Mattb85 [OP] New Member
    Hello all, i have a 2016 Tacoma TRD Sport and a little bit of a dilemma. i live about 47 miles from my work which means 94 miles a day round trip. my truck seems to average 19.5-20 miles per gallon and i believe the tank to be 17 gallons. this has proved to be pretty annoying as I'm only getting about 3.5 days to a tank which means I'm at the gas station twice a week.
    is there a way to upgrade my tank size to lets say a 25 gallon tank?
    another thought i had was buying some sort of secondary 10 gallon tank and putting it in the bed so i could just siphon the fuel into the tank when needed. however i cant seem to find a suitable tank that can be securely mounted in the bed and will not leak when the truck is bouncing around.
    any suggestions on an external tank?
    thank you
    -matt
  2. Nov 9, 2017 at 2:38 AM
    Quadabaum
    Quadabaum Well-Known Member
    2017 Tacoma TRD OR 4x4 DCSB
    265/75R16 Falkens, ADS 2.5" Stage 3 Suspension, Go Fast Camper
    kgarrett11, Dirty Harry and RIDERED67 like this.
  3. Nov 9, 2017 at 3:03 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I spoke with a guy who has one, he said in the end it wasn't worth the hassle, time, and expense of importing it. :notsure:
  4. Nov 9, 2017 at 3:20 AM
    TacoLpastor
    TacoLpastor Well-Known Member
    NC
    2016 DCLB OR 4X4
    Your tank is 21.1 gallons.
  5. Nov 9, 2017 at 3:51 AM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    How fast are you driving on this daily commute?
  6. Nov 9, 2017 at 4:23 AM
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
    The tank capacity is 21.1 gallons btw...
  7. Nov 9, 2017 at 4:26 AM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    I use to have a 76 mile round trip, I know what it's like to fill up every few days. The only thing you can do is get something with better mpg for going to work, or do what I did. I moved closer to work. If you add gas capacity you are still going to fill up, but it's going to cost more. Plus the money spent on a larger tank. Don't waste your money on a new exhaust system or intake. If you do get better mpg, it will never pay for itself. Just a bit of advice from someone who's been there and done that.
    indetrucks and Paul631 like this.
  8. Nov 9, 2017 at 4:26 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Realistically I believe that the effort that goes into siphoning your gas from a tank in the bed plus the hassle of filling both tanks when you go to a gas station is more work than it's worth (probably more time taken anyway).
    There are no larger tank options that I know of for the 3rd gens unfortunately.
  9. Nov 9, 2017 at 4:29 AM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    Prius mod
    Jessrin, Coexplorer, R11B and 3 others like this.
  10. Nov 9, 2017 at 4:35 AM
    tibadoe
    tibadoe Well-Known Member
    Joe
    Gladys, VA
    17 Tacoma SR 4X4
    Either get a better mileage vehicle or fill-up twice a week. You are not saving any time by siphoning or transferring fuel from one tank to another.
    memario1214 and Modesto Tacoma like this.
  11. Nov 9, 2017 at 4:36 AM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Not to mention the additional weight.
  12. Nov 9, 2017 at 4:46 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
  13. Nov 9, 2017 at 5:03 AM
    Hank Heel
    Hank Heel Well-Known Member
    WA
    No need to thank me
    9TRDTCO, RedRed, Spare Parts and 3 others like this.
  14. Nov 9, 2017 at 5:11 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
  15. Nov 9, 2017 at 5:11 AM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    As a rule extra capacity tanks are made for vehicles that do long range towing. Full size trucks are usually covered and trucks like the tacoma just don’t create the demand for anyone to bother making one. Now someone posted an Australian option above but as you can see it isn’t very cheap.
    I have a stand alone tank for my Kubota with an electric pump and fuel nozzle. But even that would be a bear. If you leave it in the truck and fill from there it really is no different from pulling up to a pump and filling there. If you leave it at home and top up you still have to bring it to the gas station and home again. Plus my pump system is designed for diesel. Once you go to a volatile fuel like gasoline the price of the pump triples (literally).
    I understand your desire for less fill ups but I don’t see this as a feasible endeavour. Either the cost is high or the effort negates any gains you make. (What you hope to gain is still lost on me).
    uurx likes this.
  16. Nov 9, 2017 at 5:15 AM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    A variation of this is usually the most cost effective method, which is to buy a decent older Civic, Corolla, Sentra as a daily driver.
    Hobbs and Spare Parts[QUOTED] like this.
  17. Nov 9, 2017 at 5:18 AM
    FLYH2O
    FLYH2O Well-Known Member
    2016 Tacoma TRD Sport Blue
    The fuel tank is 17 Imperial gallons.
    over60 and Paul631[QUOTED] like this.
  18. Nov 9, 2017 at 1:03 PM
    Mattb85
    i could easily be wrong on the tank size, it was a rough guess.
    1/2 my trip im going 55 mph and the other half im doing 65 mph with a little bit of city driving at one end. according to the truck itself im getting around 20mpg. im not speeding, in fact when im doing 65 the speed limit is actually 70 but i found the truck gets better mileage at 65. according to Toyota's website my gas mileage is about correct so i must be doing things right (they list it at 21mpg highway).
    i just want to be able to fill up once a week. my last truck was a 2011 GMC 1500 and this vehicle was able to make it about 6 days before refueling (it had a bigger tank and got better MPG). the price of gas varies widely and can be as much as $0.50 more a gallon if im caught in the wrong place needing gas. so a spare gas tank could at least save me some money if i run low in the wrong area.
    -matt
  19. Nov 9, 2017 at 1:11 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Routine is what you need - if you are going to drive this truck. Go three days and pick a place to fill up after 300 miles. Pick a nice station. Then you have fuel for the last two days to a half tank or so. On Monday, fill back up at the same station. Wednesday, fill back up and let the cycle repeat.
    The best solution (and cheapest) is buy you a more fuel efficient vehicle. Or trade for that Chevy you had.
    StreetTaco82 and Clearwater Bill like this.
  20. Nov 9, 2017 at 1:14 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
