Help Me Mount Offroad Lights
Discussion in '1st Gen. Tacomas (1995-2004)' started by ArtP, Mar 1, 2018.
  1. Mar 10, 2018 at 8:22 PM
    #41
    HSmith_11
    HSmith_11 Tacoma Enthusiast
    Hunter
    Madison, Va
    2001 Ext Cab SR5 4x4 MT
    5100/OME 881s 1.5" Progressive AAL 33x12.50X15 KO2s
    @CaliRaisedLed side projecting LED pods (with wiring harness) with Rago Fabrication ditch light brackets. Total cost was around $180 or so if I remember correctly. Install was pretty easy, just bolt the brackets onto your hood hinges (no trimming required and they have an install video somewhere I think) and then wiring everything up (the caliraised wiring harness is plug and play, the only tough part is getting the bundle of wires through the firewall).
    ArtP[QUOTED][OP] likes this.
  2. Mar 10, 2018 at 8:32 PM
    #42
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Get a metal clothes hanger or some other thin metal rod and tie a string to it then tie that to the wire harness. Push the metal rod through and then just yank on the string in the foot we and it should pull the wires through easily. Also slightly cutting the rubber seal where you pull the wire through helps too. Just dont cut to much, only enough so when you pull the wires through it will seal its self back up.
    ArtP[OP] likes this.
  3. Mar 10, 2018 at 8:36 PM
    #43
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Then you are probably better then me lol
  4. Mar 10, 2018 at 8:37 PM
    #44
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I have only had to do it when installing lights or stereo in my buddys cars
  5. Mar 10, 2018 at 8:40 PM
    #45
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Trick is to tie the string on the harness somewhere farther back from the tip so then you pull it through it folds on its self. If you try pulling at the tip there is a chance one of the loss wires will snag on something
  6. Mar 10, 2018 at 8:49 PM
    #46
    ArtP
    ArtP [OP] Well-Known Member
    Art
    Lake County, CA
    2003 Tacoma 4x4 Manual TRD
    Others might get use out of this thread, I'm going to delete our back-n-forth for clarity. Just know I appreciate your help!!
    MMoreno16 likes this.
  7. Mar 10, 2018 at 9:11 PM
    #47
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    No problem
