Help me narrow down this squeal...pictures inside.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MGH-PA, Nov 21, 2009.
  1. Nov 21, 2009 at 7:42 AM
    MGH-PA
    MGH-PA [OP] Well-Known Member
    Northcentral, PA
    05 Tacoma TRD AC 4x4
    265/75/16 Nitto Terra Grapplers, Bestop
    Alright, so some of you might have caught some of my previous posts on here about this squeal I'm dealing with during cold starts. I replaced my serpentine belt in August due to a similar squealing. Problem solved. Then a month or so ago, I started getting another squeal from the belt area, but this time, it lasts a little longer (about 5-10 minutes during driving depending on temperature). The squeal (unlike last time) gets WORSE and LOUDER with acceleration. When it first started, if I let off the accelerator, it went away. Now it doesn't go away, it just quiets down a little. The noise itself goes away after a while of warm-up.
    So I've finally started troubleshooting.
    I sprayed the belt with a little brake cleaner to no avail.
    I checked the belt, and it's in good condition.
    I finally went out and dropped my skid, released the tension, and spun all of the idler pulleys. They all seem to spin fine, (the tensioner pulley might have a littler resistance to it, not sure). So instead of going out and dropping $100+ on all new pulley's, I want to make sure that's really the issue.
    I was unable to isolate the noise to one particular area, either.
    Here are the pictures:
    Picture looking up at the tensioner pulley.
    Here's a shot of the belt. Gives you an idea that it's still in good condition.
    Finally, the only thing that concerns me. There seemed to be some leak signs (maybe in the past) on the PS pump here (although the squeal didn't seem to be coming from this side of the bay):
    Does anything stand out to you guys here? I guess my only option now, though, unfortunately, would be to start with the pulleys. Should I start with the tensioner first since much of my research turned up that it's the first one usually to go off all the pulleys?
  2. Nov 21, 2009 at 7:44 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I would replace the tensioner pully. Most of the time, and by that I mean all the times I have heard of this issue, it has been that pully making the noise.
  3. Nov 21, 2009 at 7:47 AM
    MGH-PA
    Northcentral, PA
    Ok, thanks. What's the torque specs on that?
  4. Nov 21, 2009 at 7:53 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    27 ft-lbs.
  5. Nov 21, 2009 at 7:54 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    # EM-40
  6. Nov 21, 2009 at 7:56 AM
    MGH-PA
    Northcentral, PA
    As always, thanks Chris.
  7. Nov 21, 2009 at 7:59 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  8. Nov 21, 2009 at 9:13 AM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Looks to me like you have a leak somewhere, judging from the 2nd and 3rd pics. Maybe your leaking oil (could be power steering) and it it dripping on a pulley or the belt causing it to slip.
  9. Nov 21, 2009 at 10:48 AM
    swise
    swise TRIFECTA!!!
    ohio
    08 4x4 dbl cab, TRD offroad
    maybe its the screw driver thats making all the noise:)
  10. Nov 21, 2009 at 11:14 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Maybe it's just me, but it looks like that belt is pretty loose...
  11. Nov 21, 2009 at 11:28 AM
    MGH-PA
    Northcentral, PA
    Picture was taken with tension relieved on the belt (note the screw driver in the first pic);)
  12. Nov 21, 2009 at 1:44 PM
    MGH-PA
    Northcentral, PA
    Well, now I'm a bit worried. Power steering fluid is low, there is evidence of at one time a leak (or currently) on the PS pump. However, there's no fluid under the truck, no whirring sound when turning the wheel, etc.
    I checked more carefully this evening, and checked the lines coming in and out of the pump, and I couldn't see any leaks. I have no idea where that residue you can see in the last picture.
    Thoughts?
  13. Nov 21, 2009 at 1:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It may have had a leak at one time. Clean the area, and top off the fluid to the correct level, and keep an eye on it.
  14. Dec 6, 2009 at 10:16 AM
    eyball
    eyball Well-Known Member
    Dudley, MA
    20 Double cab TRD Sport Voodoo Blue
    Did you end up replacing the tensioner and did this solve the problem? I just replaced the lower idler pulley as it had some resistance but that did not solve my issue.
  15. Dec 6, 2009 at 11:35 AM
    Rhino8541
    Rhino8541 I like ze best!
    WA
    2017 QS DCSB OR
    Well thats your problem right there, seems like you have a screwdriver stuck in there! Just kidding, but seriously, I know your pain, I've gone through 2 pulley replacements already.
