help me not get scammed...going to check out some wheels
Discussion in 'Arizona' started by hamNswiss on rye, Nov 8, 2011.
  1. Nov 11, 2011 at 6:13 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '10 4x4 DC SR5
    WeatherTech liners, Kenwood Media Receiver, Alpine S 6x9 speakers, Sound Ordnance 8" Sub, OEM running boards, MK6 wheels, Dynapro ATs, Tint, Bed Mat, Avid light bar, KC Daylighters
    Different angle on the valve stem holes. You can try to flip them but everyone told me flipping them makes them more prone to breakage when you install or remove a tire from a rim. Don't know if that's true or not but I just made a pvc air chamber and put my TPMS sensors in it to bypass the light. I lived just fine before TPMS, it's nice to have but not absolutely needed.
  2. Nov 11, 2011 at 7:04 PM
    hamNswiss on rye
    hamNswiss on rye [OP] ¡Yo Quiero Taco World!
    Nick
    Scottsdale, AZ/Portland, ME
    '07 4x4 Access Cab
    OME 885's and billies all around, allpro apex front bumper, Nfab tire carrier, black magic rallye 1000 driving lights, custom back to the future light rack, KC LED Daylighters, PIAA 510 fogs, bed lights, satoshi, 285/70/17 Duratracs
    fuuuu...so fashioned something to make them work? or just so they wouldnt break? mind me asking how you did this (a little more in depth)? was it tough? ugh, i dont want to deal with these damn things!
  3. Nov 11, 2011 at 7:41 PM
    Polymerhead
    Missouri
    '10 4x4 DC SR5
    You can basically build a pressurized chamber and air it up to 30 PSI. They don't "work" - as in they don't monitor tire pressure anymore. The chamber is just so the annoing TPMS dash light stays off.
    http://www.tacomaworld.com/forum/wheels-tires/174922-anyone-built-tpms-pipebomb.html
    There are alternatives, like the wheel strap kit that someone else mentioned. No experience with those. You can also pay like $125/pc for alloy-compatible sensors as well...
  4. Nov 11, 2011 at 7:51 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    If you build a chamber do not make it out of steel ( I did it and it would not pick them up through the metal ).
    If you use plastic make sure it is PVC sch. 40 at least. Do not use ABS it is not made for that kind of pressure needed.
    PM me and I can elaborate a bit. Worse thing is you get the light all the time if you don't put them in.
