Help me with a combo!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by shook0002, Sep 10, 2010.
  1. Sep 10, 2010 at 11:49 AM
    shook0002
    shook0002 [OP] "The Fuzz"
    Joe
    Philly
    '08 Doublecab 4X4 SR5
    Ok my heads spinning from all the looking. I pretty much decided on my wheel/tire combo, which will be 285-70-17 on procomp polished 1059's. Now my dilemma is a lift to accomodate it. In a earlier post I was thinking a 3" readylift kit. I'd like to hear suggestions. Maybe 5100's set at 2.5? Also any rubbing. Some do some don't from my searching. I'll be doing some light offroading, no rock climbing, jumping, etc.
    Thanks
  2. Sep 10, 2010 at 5:44 PM
    stinky_truck
    stinky_truck Well-Known Member
    ryan
    i=13 miles currently @ 75,500 miles
    Plane Jane:4x4,6 speed, shortest bed,URD3SC
    front baja bbq hoop bumper and rear allpro bumper, URD SCIII,urd short throw & stg IIIclutch combo kit w/throwout, DDM Hid 4000k, icon frt (coil overs)& rear shocks (piggy back rez)& add a leaf.
    what kind of cash are we playing w?
  3. Sep 10, 2010 at 6:13 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I've been doing a *lot* of research on this since I'm currently shopping for lift, rims, tires for my 2011.
    I've decided on a 285 70R17, same as you. Folks successfully run that size, but you have to be careful. That's a size that's prone to rubbing a lot on our wheelwells.
    Here's a cautionary thread:
    http://www.ttora.com/forum/showthread.php?t=146177&highlight=285%2F70R17
    Now, you've chosen a 9" wide wheel - that will stick out pretty far with the 4.625 backspacing and -8mm offset, and make for even more rubbing. The mounted tire may well be a full half inch wider on that rim than the same tire would be on an 8" rim! BUT I keep seeing pictures of Tacos with Moto Metal 957s, which are a 17x9 with -12mm offset!
    Tire sizes vary based on brand as well.
    A lot really depends on how you're gonna wheel it. I was talking to one installer who said something like "just don't turn the wheel all the way to the locks" - and that's certainly one option. Personally, I plan to stuff 'em hard, so I'm not gonna risk it.
    Anyhow.... you might want to reconsider to an 8" wide wheel - just my two cents.
    Also if you're going to wheel hard, be prepared to remove the mudflaps, trim away considerable plastic inside the fender well, and cut & cover the body cab mount.
    Here's a thread that describes this process well: http://www.tacomaworld.com/forum/wheels-tires/78831-33s-trimming.html
    Now, for the lift, opinions vary widely. Personally, as inexpensive spacer lifts go, I liked the reviews of the RevTek, which mixes a preload spacer with a top spacer and a differential drop to get to 3" without stressing any one part too hard. It's available with either add-a-leaf or block rear, according to your taste. Les Schwab installs those, as do many other shops, including 4 wheel parts.
    That being said, many would die or sell their trucks before putting on a spacer, so be forewarned that strong opinions lurk here.
    If there's a 4wheel parts in your area, they've got a killer "installed for free" deal going right now on this Procomp 3" suspension lift with real springs and shocks, when you order over the internet.
    Here's the offer:
    http://www.4wheelparts.com/special-deals.aspx?deal=1314
    Here's the lift kit:
    $498 2005 TOYOTA TACOMA Pro Comp Suspension 3" Lift Kit with Front ES6000 and Rear ES9000 Shockshttp://www.4wheelparts.com/prodDetail.aspx?partno=EXPK5075B
    The hangup is, again I talked with my potential installer (not 4 wheel parts) and he rang up his pro comp rep, who said that particular liftkit is on 41 days of back order! So if 4WP doesn't have it already in their warehouse somewhere, you could be waiting a while...
    5100s is a good option - but that doesn't lift the back, so you need to pick an Add-A-Leaf or lift block to get the rear higher.
    If you're willing to spend more and get a better ride and more off-road capability, well, there are even more options to make your head spin.
    Here's the thread that's describing the options I'm considering: http://ttora.com/forum/showthread.php?p=2031899#post2031899 (I posted a similar thread here on TacomaWorld but got zero response so far. The TTORA guys have been giving me a lot more feedback - that's why I sent you that link instead)
    Anyhow, this forum and the TTORA forums have LOTS of "lift my tacoma" FAQs that you can access by following sticky posts at the top of the forum.
