Help! My new Tacoma keeps getting me pulled over by the law.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rock501, Aug 31, 2012.
Thread Status:
Not open for further replies.
  1. Aug 31, 2012 at 8:41 PM
    #41
    Larry
    Larry CARL
    CARL
    pretty sure posts #2 & #3 are the simple fix.
  2. Aug 31, 2012 at 8:44 PM
    #42
    FarmBoyTaco
    FarmBoyTaco Work Hard, Stay Humble
    Josh
    California
    '12 TRD Off-Road DCSB MGM
    And you were complaining about other people being dicks.
    1) If you get in an accident the other person can claim they didn't see you because you didn't have your lights on. You may try to say different, but your tickets prove other wise.
    2) Drunk people have slow reaction times, and what if one is making a turn as you are driving in the intersection but he didn't see any lights?
    It's for your safety, maybe you should have focused on the part of his comment where he was talking about other people seeing you and not just your privilege of being able to drive.
  3. Aug 31, 2012 at 8:48 PM
    #43
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    because yer an idiot... we should give a fuck ?
    Do you need help with your safety belt as well ? :rolleyes:
    learn how to properly operate yer junk...
    or get a donkey and cart and stfu
    Turn on your lights... foo'
    and be mad at no one, but yourself.
  4. Aug 31, 2012 at 8:51 PM
    #44
    rsbmg
    rsbmg Well-Known Member
    Rob
    Vista,CA
    2011 Tacoma Doublecab TRD Offroad
    Front Aluminum bumper by Relentless Fab. Smittybuilt Winch Complete set of skids by ATO TC UCA's Fox Ext. Travel Front Reservoirs.
    It appears you live in Texas so
    Sec. 547.302. DUTY TO DISPLAY LIGHTS.
    (a) A vehicle shall display each lighted lamp and illuminating device required by this chapter to be on the vehicle:
    (1) at nighttime; and
    (2) when light is insufficient or atmospheric conditions are unfavorable so that a person or vehicle on the highway is not clearly discernible at a distance of 1,000 feet ahead.
    (b) A signaling device, including a stoplamp or a turn signal lamp, shall be lighted as prescribed by this chapter.
    (c) At least one lighted lamp shall be displayed on each side of the front of a motor vehicle.
    (d) Not more than four of the following may be lighted at one time on the front of a motor vehicle:
    (1) a headlamp required by this chapter; or
    (2) a lamp, including an auxiliary lamp or spotlamp, that projects a beam with an intensity brighter than 300 candlepower.
    And here is how "nighttime" is defined:
    Sec. 541.401. MISCELLANEOUS TERMS.
    In this subtitle:
    (5) "Nighttime" means the period beginning one-half hour after sunset and ending one-half hour before sunrise.
    Did you have any other questions? Turn your lights on people have been doing it since 1898, if its difficult for you perhaps consider public transportation.
  5. Aug 31, 2012 at 8:54 PM
    #45
    Darth_Yota
    Darth_Yota I intend to live forever, or die trying.
    Cam-moron
    Somewhere USA
    Dented, broken-down ‘08 hoopty
    Ain’t good’nuff for insta
    Get a flow for the cabin for night driving. Essentially a checklist.
    Example: ignition on, start engine, then work left across the panel. Lights, verify lights on with the green indicator in gauge cluster, check rpm, engine temp, parking brake, radio and pump the tunes.
    You get the idea...
  6. Aug 31, 2012 at 8:55 PM
    #46
    lawless
    lawless the rent is too damn high
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    wonder how this is gonna end up?
  7. Aug 31, 2012 at 8:56 PM
    #47
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    like some said. just turn them on and leave them on. they turn off when you open the driver door any ways. that’s usually what i do in my ’07.
  8. Aug 31, 2012 at 8:57 PM
    #48
    acdronin
    acdronin Well-Known Member
    OOPS!
    More OOPS!
    Mega OOPS! (rears, bulbed and wired)
    No one, and I mean NO ONE can ever say they didn't see me
  9. Aug 31, 2012 at 8:58 PM
    #49
    Larry
    Larry CARL
    CARL
    I hope the OP takes the advice of the the folks here and keeps his driving record clean...and public roadways safe.
  10. Aug 31, 2012 at 9:17 PM
    #50
    staymates788
    staymates788 Well-Known Member
    SEAN
    Anaheim, CA USA
    2005 4x4 Double Cab Long Bed w/ TRD Sport
    California Vehicle Code Section 12500(a) " A person may not drive a motor vehicle upon a highway, unless the person then holds a valid driver's license issued under this code, except those persons who are expressly exempted under this code."
    And before you try to argue the exemptions, that refers to Driver's Licenses issued by other states are valid while you visit CA.
    Obviously not everyone lives in CA, but I think it is very safe to assume each state has similar laws.
  11. Aug 31, 2012 at 9:19 PM
    #51
    Rock501
    Rock501 [OP] Well-Known Member
    Stafford, Texas
    07 PreRunner, TX edition with factory 20's
    yes, the op will
    the op was hoping someone was going to come up with something like this
    http://www.tacomaworld.com/forum/technical-chat/1475-05-drl-daytime-running-lights-install-oem.html
    and well, here it is. So Im going to do this... sorry if i got defensive and pissed off, you have to understand how i came into this naturally a little mad at the whole situation, and the fact that it was such a bullshit little mistake.
    this is why i never got pulled over with my lights running lights that came on automaticly with my old truck, they were bright enough.
    So ill make this mod with my fog lights, and for extra measures, ill seek out some stronger bulbs and make a post-it note, and drive around with out my gauges lit during the day, and leave my headlights on all the time, since I can have:
  12. Aug 31, 2012 at 9:32 PM
    #52
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
  13. Aug 31, 2012 at 9:34 PM
    #53
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Is the truck getting you pulled over or are you getting you pulled over?
    Sounds like you had a habit of not turning your lights on with your other truck as well. Seems to me you'd simply be better off learning how to turn your lights on, rather than finding ways to keep yourself dummified. Before the Tacoma I came from 7 yrs in an S-10 which had automatic headlights, so I know how it is to start driving a truck you have to actively turn the lights on with. Notwithstanding, I had zero problems figuring out that I need to turn my lights on when it's DARK OUTSIDE.
  14. Aug 31, 2012 at 9:35 PM
    #54
    xJuice
    Josh
    N. Texas
    19 Tundra MGM
    Correct.
  15. Aug 31, 2012 at 9:42 PM
    #55
    RadSurfTaco
    RadSurfTaco Well-Known Member
    In Ocean or My Taco...trolling up & down Hwy 1
    09 PreRunner MGM DC SB
    If you aren't able to follow the rules of operating a motor vehicle, then take a bus and exercise your god given right to travel the highways.
    But, on another note, why not set up a light on your dash that can only be turned off when you put your lights on. It could be a bright LCD in maybe an annoying bright green light or even something like blue or white. Once you turn your lights on, off goes the annoying bright light.
  16. Aug 31, 2012 at 9:45 PM
    #56
    shweller
    shweller Well-Known Member
    Corona
    2010 Tacoma TRD Sport SB 4x4
    PoP 'N' Lock Satoshi Grill (Did it Myself) DSM UCA's (Desert Products) FXR 1.1 w/Gatling Gun Shrouds Phillips 85122 Method Racing Wheels HID Hella 500's behind Satoshi grill Fog Light Anytime Illuminated 4x4 Switch Ultragauge PIAA 510"s King Coilovers w/resi's Rear TSB Leaf Packs All Pro Sliders Bolt on sliders 255/75 R17 BF Goodrich Mudders Spidertrax wheel spacers Neoprene arm rests Weathertechs Wet Okoles w/TRD Allpro Ofrroad Apex bumper and IFS skid plate
  17. Aug 31, 2012 at 9:45 PM
    #57
    File IFR
    Central MA
    Be careful of what larger watt/size bulb you place in the marker light socket, you could overheat the wires or relay.
    .... I'm not trying to shatter your dreams, I'm just being realistic.
  18. Aug 31, 2012 at 9:45 PM
    #58
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    Now I am drunk, but I know how to operate my Junk.
    Yah and my headlights too.
  19. Aug 31, 2012 at 9:46 PM
    #59
    Dragons Taco
    Derek
    Cary/Raleigh NC
    So, ah no 100watt bulbs eh?
  20. Aug 31, 2012 at 9:46 PM
    #60
    staymates788
    SEAN
    Anaheim, CA USA
    Very true. My work truck is a 2006 Chevy 2500HD with automatic lights. I drive it daily during both daytime & nighttime. I have never had a problem remembering to turn on my headlights in my taco.
Thread Status:
