Help...need answers pls
Discussion in 'Toyota Trucks & SUVs' started by Angelalorenzo, Feb 3, 2013.
  1. Feb 3, 2013 at 1:16 AM
    Angelalorenzo
    Angelalorenzo [OP] Member
    Angela
    2000 Toyota Tacoma regular cab pick-up
    1st, has anyone replaced a steering wheel for a 2000 Tacoma pick-up? When replacing the steering wheel with an after-market one, can the black piece be removed from underneath the steering wheel? (Black piece that has the airbag and horn connecter)...only because I can't fit the after-market steering wheel kit for the '96-'04. THANK YOU in advance...
  2. Feb 3, 2013 at 2:24 AM
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    yikes... I don't have any experience in this but going to give you a Bump for the early risers who may know.. do you have a Haynes manual?
  3. Feb 3, 2013 at 2:28 AM
    Angelalorenzo
    Angela
    Nope, but this is a photo I took of it...Thanks for the Bump! This can be removed, but is there a way I can install the kit without removing it...if I do, I won't have a horn...OUCH! Or is there a way.....
  4. Feb 3, 2013 at 2:48 AM
    Jeffvt0508
    Jeff
    Anderson, SC
    what aftermarket kit do you have?
  5. Feb 3, 2013 at 5:37 AM
    Angelalorenzo
    Angela
