Help needed for diff bearing
Discussion in 'Northern California' started by tacomtn, Mar 29, 2012.
  1. Mar 29, 2012 at 4:33 PM
    tacomtn
    tacomtn [OP] Well-Known Member
    TRD OR,OME,Deaver AAL
    If anyone can help me install a front diff bearing I could sure use the help. I have the necessary tools and garage.
    Anyone?
  2. Mar 29, 2012 at 10:32 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Did you get the bushing from Chase?
  3. Mar 29, 2012 at 11:37 PM
    tacomtn
    Yeah, from Chase and also CVJ from the GB. Removal and install tools from Chase also. I'd hate to try this on my own, then run into a problem with the truck apart. That's why at least I could use an extra hand.
  4. Mar 29, 2012 at 11:48 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    A location would help tremendously
  5. Mar 30, 2012 at 9:28 AM
    tacomtn
    I'm in San jose
  6. Apr 6, 2012 at 2:40 PM
    tacomtn
    Anyone????? The growling is getting worse. Help appreciated.
  7. Apr 6, 2012 at 3:35 PM
    SCRunner12
    SCRunner12 Tundra Troll
    Robert
    Santa Cruz, CA
    2006 Tundra DC, TRD, 4wd
    There's a mod day on May 5th. There definitely will be a bunch of people to help then.
  8. Apr 6, 2012 at 3:42 PM
    05Moose
    Jim
    If San Jose wasn't so darn far, especially at these gas prices, I'd be all over this. If you go to the Mod day, I'd be inclined to go and help.
  9. Apr 6, 2012 at 4:50 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Yeah, bring it to the mod day.
    EDIT: I feel bad that you originally posted up in that thread and I originally replied that I thought you had to completely remove your diff and crack it open... - obviously since then I've found out otherwise. :eek:
    But we can pop a CV axle out, use that "Chase Bearing Puller" and put the CV back in within the scope of a mod day.
  10. Apr 6, 2012 at 5:09 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    If you decide to take it on before then, this thread:
    http://www6.tacomaterritory.com/forum/showthread.php?p=1730717
    will show you the steps to removing the spindle and CV, and getting access to the driver side bearing.
    I can't imagine pulling that 35mm axle nut without an electric or air impact wrench. There's just no effin' way.
    You'll need a replacement axle cotter pin.
    The hardest thing to do the first time you've ever done it, is remove and reinstall the CV axle itself.
    You'll want these tools: 4lb hammer and Sears Craftsman prybars (they're in the automotive department, not the tool department, and they come in a pack of 3)
    Here's how you position the prybar on the CV axle:
    With a closeup on the axle itself:
    This bottom pic, shows the axle after it's been driven out of position about an inch and a half, and ready to be removed by hand the rest of the way.
    Then an authoritative whack with the 4lb engineer's hammer. Don't try and use a claw hammer - it doesn't convey nearly enough energy.
    For reinstalling, it's the opposite. The trick is - the splines on the axle have to be aligned within the splines that accept them within the differential, and that's a "feel" thing. If they're lined up right, one or two "authoritative" whacks will drive it home. If they're not, you can hammer that m*th**f****in CV axle until the splines are actually FLATTENED, ruining it. So the drill is:
    "place, WHACK! WHACK! check - is it driving in?" If not repeat from the placement step, don't just keep mindlessly hammering.
  11. Apr 7, 2012 at 1:16 AM
    tacomtn
    BJ. Thanks so much for this info. I really needed that. I'd go to the mod day but can't that day. I need to get this done sooner than later before the growling turns into a lion's roar.
  12. Apr 7, 2012 at 10:44 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Saw some guys wrap wire around the cv and then use a small sledge to knock it out (slide hammer-esque). It's not too bad getting it out. Nor too bad getting it in.
