HELP NEEDED--Icon rear res shocks and bump stop install tips/tricks
Discussion in 'Suspension' started by Erik65, Jun 1, 2013.
  1. Jun 1, 2013 at 4:45 PM
    Erik65
    Erik65 [OP] Dog slave
    Erik
    Oxford, MA
    2011 Timberland Mica TX Pro DC
    Stainless exhaust, 16" TRD wheels, 285x75x16 MTR Kevlars, Icon Stage IV, Icon Secondary shock hoop with adjustable remote reservoir bypass shocks, ATO shackle flip kit, AP U-bolt flip, AP Skids (IFS, transmission, T-case, diff cover)
    Doing my stage 4 install and noticed that installing the reservoir on the 2.0 rear shocks is going to be a challenge because of the mounting brackets for the hydraulic air bump stops getting in the way of routing what appears to be a too-short reservoir hose. Anybody running this settup have any tips for this mounting (pun intended) conundrum?
  2. Jun 1, 2013 at 5:31 PM
    06HAOLE
    06HAOLE Well-Known Member
    Sherman Oaks, CA
    The Icon photos show the resi hose running across the bumpstop bracket. Try and arch the hose so it isn't tight across the bracket and chafe the hose. You may have to drill another hole for resi bracket that is closer to the bumpstop bracket since you are changing angle of resi hose.
  3. Jun 1, 2013 at 6:16 PM
    Erik65
    Erik
    Oxford, MA
    Good point--thanks for the reality check
